Can i configure RV340 LAN port as WAN (to use 3rd ISP) as load balanci
veeamkay
my question is can i configure LAN port in RV340 as WAN port to use my 3rd ISP as load balancer, where 2 other WAN are already Online.
marce1000
 - FYI : https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/KMGMT-1568_WAN_Load_balancing_on_RV340_Router.html
 M.
balaji.bandi
i do not believe RV support more than 2 WAN connection. Since GUI has fixed config, you can not add LAN interface in to 3rd connection.
BB
on 1st page you can read, this device has several WAN ports the only problem is they are not Gig ports.
how come RV340 lacks this functionality.
i am amazed at Cisco
can anyone suggest any other RV model which can do this at Gig speed ?
https://www.cisco.com/c/en/us/products/collateral/routers/rv016-multi-wan-vpn-router/data_sheet_c78-501223.pdf
Your link was for an older mode (RV016). The RV340/345 can do Gigabit speeds:
https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/datasheet-c78-742350.html
But, their end-of-life is rapidly approaching (with no security updates after the EOL).
