Cisco RV340 VPN - VPN connection problems
Drindal
Hi all,
i've bought a Cisco RV 340 VPN Router for my network. Behind my router there are 2 cisco managed switches. The internet is provided by a cable modem which is configured in bridge mode.
I've tried to set a VPN up, but i can't connect to my network from outside. I hope you can give me some advise.
I've taken several screenshots from the config page.
WAN Settings:
WAN1: connected to cable modem
LAN settings: the switches are connected to lan4
VLAN settings:
VLAN1:
Firewall:
Access Rules: I've defined 2 new rules to gain access to my home automation server
VPN Settings: i've tried with client-to-site, vpn ssl and pp2p, but neither one of them was working
SSL VPN configured at the moment:
System configuration:
Modem IP 192.168.0.153
LAN: IP Range 192.168.1.1 - 192.168.1.255
I've installed the anyconnect secury mobility client. But i can't connect to my network.
I've tried with and without port 8443:
I hope someone can give me a hint what could be wrong with my setup.
Thanks!!!
Drindal
balaji.bandi
on what IP VPN trying to connect from externally ?
If the ISP offering RFC 1918 address this is not going to work, you need to contact ISP for the Public IP,
or use any dynamic DNS Server ?
BB
The public ip is 90.146.*.* I've also a dyndns account connected.
Drindal
I've called my ISP to check my modem. It's set so bridged mode. The strange thing is, wenn i go to the system summary page, the wan IP is the IP address, which assigned the modem to the router.
when i do a "what's my ip"-lookup , my PC is recogniced as 90.146.*.*
But if a activate my dyndns account, the dyndns is connected with 192.168.1.151. The modem has an active dhcp server, an assigned 192.168.1.151 to my router. is this the problem?
