Cisco RV345 DMZ configuration
julenGenelek
We have this network configuration in RV345:
WAN1:
ip: 192.168.1.11 /24
VLAN1
ip: 192.168.3.11 /24
Hardware DMZ
Enabled (port 16 to DMZ)
ip: 192.168.2.11
mask: 255.255.255.0
DMZ Host
Enabled
ip: 192.168.2.11
I'm trying to allow traffic from DMZ to Internet but I can't, ping to 8.8.8.8 not responding from a computer in DMZ with 192.168.2.100 ip.
The access rules (basics for test) i have configured:
DMZ to WAN1 - All traffic - Source: any - destination: any - Allowed
WAN1 to DMZ - All traffic - Source: any - destination: any - Allowed
But this configuration is not working.
What am I missing?
Thanks!
Julen.
PD: I attached configuration screenshots:
Access_Rules.pngFirewall-DMZHost.pngHardware_DMZ.pngVLAN_Settings.png.
10 Replies 10
omz
Yes, from the host 192.168.2.11 (this host is RV345 firewall on the DMZ port) i can ping 8.8.8.8 but from a computer behind firewall DMZ I cannot.
Thanks for reply.
I attached configuration screenshots.
julenGenelek
I've seen they are a lot of issues about DMZ port in Cisco RV series without solve........
I think he cisco support should say something...
julenGenelek
Any idea?
julenGenelek
I need help... Thanks!
Sorry not familiar with RV345s. Just try to help from guides.
Maybe try -
3. Select Subnet to identify a subnetwork for DMZ services and enter the DMZ IP Address and Subnet Mask.
4. Select Range (DMZ & WAN within the same subnet) and enter the IP range
The host in DMZ host is working as expected, right?
Maybe add the range from the DMZ subnet as well.
I think the issue is in the Firmware because I've disabled the Hardware DMZ and created an VLAN with subnet 192.168.2.11/24 in the 16 port and limited the acces with rules like DMZ and it works. For that reason I think the problem is in the Firmwar and how it manage the DMZ port, I think there is a problem with the NAT o Routing between LAN/WAN ports and the DMZ port.
If you have valid Cisco contract, please raise a case with Cisco TAC and they will be able to confirm.
Sorry, could not be more helpful.
tokens
Hi there,
Any update on this, please?
I have the same problem setting up RV345 Hardware DMZ.
Thank you in advance.
