Cisco rv345
Hi all.
I bought a Cisco rv345 but I can't get it working. When I plug the cable from ISP into my PC I have full speed. When I then connect the router to ISP the speed almost completely disappears. What am I doing wrong?
balaji.bandi
depends on how you configured the device, if you enabled all the feature, it will be slow.
so disable most of the features not required and try.
BB
I have a speed of 1000 Mbps without the router but about 10-50 Mbps with the router.
I don't expect it to be that slow. I haven't made any changes to my router.
is this new Router?
couple of things to check :
1. check the speed negotiation between ISP modem and WAN Port of RV Router
2. post the configuration screenshot of device config.
3. Speed 1GBPS? without a router, can we have screenshot?
4. how are you connecting PC to router what port ?
BB
Did you use the "initial setup wizard"? It is probably the best way to start and then makes changes after running the wizard.
