Cisco RV34x DHCP scope /23 ?
Rhenus001
Hi there,
We are looking for a SMB router where we can have a /23 DHCP scope. Is the RV340 capable of supplying a range of +400 addresses?
We could lower the lease time as we do not have over 150 clients simultaneously on this internet breakout but I'm wondering which technical solution would be best.
Ronald Groenewegen (NL).
psandel
Hi Ronald,
My name is Puneet Sandel and I am from small business technical support center.
As per your query I will like to make you aware that RV340/345 routers have range start and end field under DHCP configuration.
For a single VLAN, RV34x routers can provide dynamic IPs for CIDR value 23 also.
I am enclosing a screenshot for your reference. In the screenshot I have given DHCP range from 192.168.4.100 to 192.168.5.149 and prefix length is 23 (VLAN 1 Network being 192.168.4.x/23).
Note: Please mark this post as the solution as the RV34x routers support this feature.
Puneet Sandel
Technical Consulting Engineer-Level 2
Global CX Centers – Small Business Support
psandel
Hi Ronald,
Puneet Sandel
