Cisco RVS4000 vs Linksys RVS4000 Firmware
broadwaygreg
I have both Cisco RVS4000 & Linksys RVS4000 routers in Use.
I can only find Firmware V 1.4.1.2,
I have updated all my CISCO branded Routers.
Will this File work with my Linksys Routers as well.  They have V 1.1.14 now.
Greg.
riroe
Level 3
Level 3
Version 1.4.1.2 is the latest version for the QVPN Software.  This is not firmware for the actual router. The latest firmware for the RVS4000 is
1.3.2.0  however if you have a hardware version 2 of the RVS4000 the latest firmware for it is 2.0.0.3.  It can only be loaded on the RVS4000 Version
2 hardware.
THANKS
Rick Roe
Cisco Small Business SUpport Center
I am new at this, but where do I find the firmware update? And how do I update the router?
Hi tyler0009,
You will find the latest firmware here: https://software.cisco.com/download/navigator.html?mdfid=283005379&catid=268437899
However, if you download Cisco FindIT, this tool will tell you when the latest firmware is available and update it for you.
Cindy
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
