09-12-2023 12:10 AM
The router is hanging in the condition shown in the photo below. LAN connection is not recognized by the Windows machine. Is this device bricked? What are my options to get it working? Is there a way to flash firmware with Console to USB cable? Thanks for your input.
Holding reset button straight after POWER ON have put it into continuous reboots state, but the router ended up in the same condition after some time.
09-12-2023 03:20 AM
- Do you get any outputs when attaching an usb console ?
M.
09-12-2023 10:58 PM
09-12-2023 11:02 PM
- Make sure the baud rate is correct ,
M.
09-12-2023 11:19 PM - edited 09-13-2023 01:26 AM
It is giving this output with 115200 b.r.
uloader 2011.06.0 (Nov 19 2018 - 21:20:11)
Board: Mindspeed C2000 900 MHz
nand_probe: comcerto_nand base: 0xc8300000 size: 0x512 MB
ONFI flash detected ... ONFI param page 0 valid
NAND device: Manufacturer ID: 0xc2, Chip ID: 0xdc (<NULL> MX30LF4G18AC), page size: 2048, OOB size: 64
Copying Barebox from NAND Flash(bootopt=0) @offset = 0x0
Reading ...
Done...Bytes read 0x100000
Image verified and authenticated
## Starting Barebox at 0x01000000 ...
barebox 2011.06.0-dirty (Nov 19 2018 - 21:19:30)
calling dus_out_of_reset:
c2k_spi_flash_probe: size : 0x00400000
c2k_otp_probe.
cbus_baseaddr: 9c000000, ddr_baseaddr: 03800000, ddr_phys_baseaddr: 03800000
class init complete
tmu init complete
bmu1 init: done
bmu2 init: done
util init complete
GPI1 init complete
GPI2 init complete
HGPI init complete
HIF rx desc: base_va: 03e80000, base_pa: 03e80000
HIF tx desc: base_va: 03e80400, base_pa: 03e80400
HIF init complete
bmu1 enabled
bmu2 enabled
pfe_hw_init: done
pfe_firmware_init
pfe_load_elf
pfe_load_elf no of sections: 10
pfe_firmware_init: class firmware loaded
pfe_load_elf
pfe_firmware_init: tmu firmware loaded
pfe_load_elf
pfe_load_elf no of sections: 14
pfe_firmware_init: util firmware loaded
miidev_restart_aneg for PHY1
Using ENV from SPI Flash.
Scanning device for bad blocks
Bad eraseblock 1001 at 0x07d20000
Bad eraseblock 3428 at 0x1ac80000
Malloc space: 0x00100000 -> 0x01100000 (size 16 MB)
Stack space : 0x01200000 -> 0x01208000 (size 32 kB)
.envfs: wrong magic on /dev/env0
no valid environment found on /dev/env0. Using default environment
running /env/bin/init...
Setting env LAN, WAN...
LAN MAC : 4C:A6:4D:F6:73:41
WAN MAC : 4C:A6:4D:F6:73:40
done
Exporting env LAN, WAN...done
FOUND MACs from Boardinfo using same in bootargs
eth0mac = 4C:A6:4D:F6:73:40, eth1mac = 4C:A6:4D:F6:73:41
done
Setting active/inactive env...
done
Exporting env...done
active = image2 inactive = image1
Booting default active image2 ...
1.0.00.03
booting kernel of type uimage from /dev/nand0.kernel2.bb
active image is corrupted. Switching to inactive image
Checking /dev/nand0.kernel1.bb ...
Verifying Checksum ... OK
Image Name: Linux-4.1.8
Created: 2018-11-19 16:49:47 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2723480 Bytes = 2.6 MB
Load Address: 03008000
Entry Point: 03008000
Booting kernel /dev/nand0.kernel1.bb with Rootfs part : 4
OK
Starting kernel ...
commandline: loglevel=4, init=/etc/preinit mac_addr=4C:A6:4D:F6:73:40,4C:A6:4D:F6:73:41 ip=none root=ubi0:rootfs ubi.mtd=4 ,2048 rootfstype=ubifs rw noinitrd mtdparts=comcertonand:1M(barebox),1M(bareboxfact)ro,1M(env),8M(kernel1),140M(rootfs1),1M(reserved_1),8M(kernel2),140M(rootfs2),1M(reserved_2),20M(configcert),12M(config_bkup),48M(webrootdb),8M(license),50M(packages),48M(findIT),24M(reserved);spi1.0:128k(uloader)ro,512k(barebox)ro,128k(env),128k(boardinfo)ro,64k(md5sum1),64k(md5sum2),64k(nvram),64k(boot_check) usb3_internal_clk=yes pcie0_gen1_only=yes pcie1_gen1_only=no pcie_external_clk=yes bareboxver=barebox 2011.06.0-dirty (Nov 19 2018 - 21:19:30) bareboxver_rv16x_26x=1.0.00.03 boot_fail_flag=1
arch_number: 1094
Uncompressing Linux... done, booting the kernel.
Reading ...
c2k_otp_probe.
class init complete
tmu init complete
bmu1 init: done
bmu2 init: done
util init complete
GPI1 init complete
GPI2 init complete
HGPI init complete
HIF init complete
bmu1 enabled
bmu2 enabled
pfe_hw_init: done
pfe_firmware_init
pfe_load_elf
pfe_load_elf
pfe_load_elf
done
done
done
active = image1 inactive = image2
Booting default active image1 ...
1.0.00.03
booting kernel of type uimage from /dev/nand0.kernel1.bb
OK
Starting kernel ...
commandline: loglevel=4, init=/etc/preinit mac_addr=4C:A6:4D:F6:73:40,4C:A6:4D:F6:73:41 ip=none root=ubi0:rootfs ubi.mtd=4 ,2048 rootfstype=ubifs rw noinitrd mtdparts=comcertonand:1M(barebox),1M(bareboxfact)ro,1M(env),8M(kernel1),140M(rootfs1),1M(reserved_1),8M(kernel2),140M(rootfs2),1M(reserved_2),20M(configcert),12M(config_bkup),48M(webrootdb),8M(license),50M(packages),48M(findIT),24M(reserved);spi1.0:128k(uloader)ro,512k(barebox)ro,128k(env),128k(boardinfo)ro,64k(md5sum1),64k(md5sum2),64k(nvram),64k(boot_check) usb3_internal_clk=yes pcie0_gen1_only=yes pcie1_gen1_only=no pcie_external_clk=yes bareboxver=barebox 2011.06.0-dirty (Nov 19 2018 - 21:19:30) bareboxver_rv16x_26x=1.0.00.03 boot_fail_flag=0
arch_number: 1094
09-13-2023 03:19 AM
- At first glance , I can't see any problems with that ; do you get a prompt when pressing return (e.g.) ?
M.
09-13-2023 04:15 AM
No, I don't. At times, when router is not rebooting continously, with all lan LEDs ON, the last output is
"Uncompressing Linux... done, booting the kernel."
09-13-2023 05:05 AM
- Tend to believe it's broken and needs RMA-ed ; for Cisco opinions :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
M.
