cisco small business Rv042 https probelem and internet navigation
raoufabassi01
Fethi(Tunisia)
hi all
I'm blocked i have big problem HTTPS/HTTP and Internet navigation it's blcocked  in the all computer in my network
some Site Http it's ok i think that's only for HTTP
Only in my computer it's OK with Windows 7 but i have the same IP/system configuration  same anti-virus  !!!!!!
tests:
ping to external public address :OK
nslookup: OK
i changed the RV042: NOT OK
i changed the Modem: NOT OK
i canceled the way(router cisco and switch) directly connnected: NOT OK
ideas:
Network =======>             cisco router c805                                       ======>        Cisco RV042      ======>      Internet
                                          Default route to rv042 adress to internet                          firewall disabled
                                          Static route to Serial FR connexion remote site
i have routeur cisco small business rv042 with modem in bridge mode
i have simple configuration ( i dont have a complicated configuration)
WAN enabled (diagnostic ping and nslookup to external:OK)
Tunnel Gateway to Gateway also enable
Do You think this probelem it's from MTU Value
I have automatec MTU
thank you in advantage to your's response
jeffrrod
Level 4
Level 4
Dear Fethi,
Thank you for reaching the Small Business Support Community.
I would first suggest you to bypass the c805 router; connect your PC’s to the RV042 directly and try to go online, if that’s OK then log in to the route, go to setup -> mac address clone and choose the option 'clone this pc mac' and apply/save this.
If the problem persists, then I suggest to run a MTU test and adjust if necessary, please check on the below document for instuctions;
http://kb.linksys.com/Linksys/ukp.aspx?pid=80&vw=1&articleid=386
Check on the computer’s operating system and antivirus firewall settings, same for the c805 router.
If the problem persists I would then suggest you to contact the Small Business Support Center for further troubleshooting;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Make sure your RV042 is running the latest firmware release available;
http://software.cisco.com/download/release.html?mdfid=282414010&softwareid=282465789&release=4.2.2.08&relind=AVAILABLE&rellifecycle=&reltype=latest
Please do not hesitate to reach me back if there is any further assistance I may assist you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
