Cisco spr 521w no DHCP ON LAN
ruant0001
I have a cisco small business spr 521w
I setup the DHCP and it work 100% on the wireless you can connect to it and it will give you an IP, but there is no response from the ethernet, i connect my laptop to the ports and nothing happens i even tried connecting the network printer to a port with an static ip but still nothing!!!
Its like the wireless and ethernet are not communicating!!!
What am i doing wrong
fb_webuser
Level 6
Level 6
DHPC should be configured:
one DHCP pool for wireless
second DHCP pool for ethernet
Check that the ethernet link is not down
Posted by WebUser Mario Boltek from Cisco Support Community App
ruant0001
Here is a screenshot
paolo bevilacqua
Wrong forum, post in "small business routers". You can move your post using the actions panel on the right.
