Configuration RV320 e PPPOE
Ulicouto
Hello guys! I'm new to the world in the universe cisco routers.
My company gets a dual router cisco dual wan for internet contigency.
I have an internet ADSL (PPPOE) in which I would like to connect the wan1 port of my router, it assigns user and authentication password of my modem to the router without success. So my question is:
Do I have to leave my modem in bright mode and the router to distribute dhcp?
Is it any problem to keep DHCP and PPPOE active on the modem and router?
Glenn Martin
THis is not the RV320 specifically, but you can try tis: https://supportforums.cisco.com/t5/small-business-support-documents/basic-setup-wizard-on-rv32x-vpn-router-series/ta-p/3171443
Also, Please click "Accept as Solution" if this helps you.
thank you Green Martin.
I will try here again.
