02-16-2017 09:50 AM
I have a Cisco 2504 Controller and 3 Aironet 1850's. I went through the express install on the controller but now need to setup the access points. I've done a lot of reading and have a few questions.
- It says "You must configure a separate DHCP pool for each access point type". It says "access point type" does this mean it's okay for me to setup just 1 pool and it will be okay to be used by all 3 access points or do I need to setup a separate pool for each access point (they are all the same type)?
- I'm setting up each access point in the controller and is no way to get into the access point itself? I'm asking this because what if I didn't have a controller and only had the 3 access points wouldn't I have to configure each? My access points didn't come with any documentation so I've been out on the web reading all that I could about them and of the documentation I've read I could not find any that tell me how to get into the access point itself to configure.
Which leads me to my next question...
- I cannot see my access points in the controller. I read "Cisco recommends that you disable Cisco Discovery Protocol on the controller and access point when connected to non-Cisco switches as CDP is unsupported on non-Cisco switches and network elements". I am using a Netgear unmanaged switch does this mean that my access points will not auto discover and if not is there a way for me to add each one to the AP section of the controller software manually?
- I cannot get into the Access Point via wireless. The documentation says, "Connect the Wi-Fi-enabled laptop to the CiscoAirProvision SSID advertised by the AP, using Wi-Fi. The password is password". I don't see any wireless being broadcasted by the SSID CiscoAirProvision.
02-17-2017 03:39 AM
Also I just want to add that I cannot configure the Access Point because it isn't broadcasting an ssid.
