Difference between RV215W-E-K9-G5 and RV215W-E-G5-K9?
peter_flanigan
What is please the difference between these two N300 routers:
>>>  RV215W-E-K9-G5
>>>  RV215W-E-G5-K9
Please try to be as specific as possible.
Thank you very much indeed!
jeffrrod
Level 4
Level 4
Dear Peter,
Thank you for reaching the Small Business Support Community.
The three available ordering part numbers for the RV215W routers are:
RV215W-A-NA-K9 (USA)
RV215W-E-G5-K9 (Europe)
RV215W-A-AU-K9 (Australia)
The two part numbers you inquire about refer to the same device, no difference.  Please check on the datasheet for further details on the specs,
http://www.cisco.com/en/US/prod/collateral/routers/ps10907/ps9923/ps12678/data_sheet_c78-712088.html
I hope this answers your question and please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
