Does IR809G-LTE-NA-K9 support Verizon?
Sam Brynes
The datasheet here says that in the United States AT&T is supported and has the phrase "FW Image Provisioning Switching" next to it. Does that mean the IR809G-LTE-NA-K9 firmware can be flashed to use Verizon?
https://www.vtkt.ru/upload/iblock/d2f/Cisco_IR809.pdf
Or do I need to actually purchase the IR809G-LTE-VZ-K9 model to get Verizon support? Just asking because I might have a few easy ways to get my hands on a IR809G-LTE-NA-K9 (but not an IR809G-LTE-VZ-K9).
balaji.bandi
IR809G-LTE-VZ-K9 - ( as per i know IR809 EOS)
https://www.cisco.com/c/en/us/products/collateral/routers/809-industrial-router/eos-eol-notice-c51-742816.html
I'm not sure if you're looking used one.
Please take a look at the below datasheet.
https://www.cisco.com/c/en/us/products/collateral/routers/809-industrial-router/datasheet-c78-734980.html
BB
Hi Balaji,
Yes, I'm looking to get a used one. Does IR809G-LTE-NA-K9 support Verizon as well? Or does it only support AT&T?
Sam
i can not answer that since i have not tested, as per the region technically should work.
BB
