02-24-2015 03:56 AM
I have tested Guest Network settings on EPC3928-A4CC-K9 running firmware 150116c
And there is not possibility to set anything via Web page using admin account and based on the CM config file (applied after factory reset through the modem button)
The settings are possible via SNMP but the Web settings are not working, but should.
Please let me know if this is a bug or we have something wrong in the config file.
Grzegorz Cegielski
CM Config file
Main
NetworkAccess 1;
SnmpMibObject docsDevNmAccessIp.1 IPAddress 0.0.0.0;
SnmpMibObject docsDevNmAccessIpMask.1 IPAddress 0.0.0.0;
SnmpMibObject docsDevNmAccessCommunity.1 String "black";
SnmpMibObject docsDevNmAccessControl.1 Integer 3; /* readWrite */
SnmpMibObject docsDevNmAccessInterfaces.1 String "@";
SnmpMibObject docsDevNmAccessStatus.1 Integer 4; /* createAndGo */
SnmpMibObject docsDevNmAccessIp.2 IPAddress 0.0.0.0;
SnmpMibObject docsDevNmAccessIpMask.2 IPAddress 0.0.0.0;
SnmpMibObject docsDevNmAccessCommunity.2 String "pokemon";
SnmpMibObject docsDevNmAccessControl.2 Integer 2; /* read */
SnmpMibObject docsDevNmAccessInterfaces.2 String "@";
SnmpMibObject docsDevNmAccessStatus.2 Integer 4; /* createAndGo */
MaxCPE 16;
SnmpMibObject ifAdminStatus.1 Integer 1; /* up - wl/wyl Ethernet */
SnmpMibObject ifAdminStatus.5 Integer 2; /* down - wl/wyl USB */
SnmpMibObject enterprises.1429.78.1.1.0 Integer 1; /* enable - wl/wyl MTA */
SnmpMibObject enterprises.1429.79.2.1.1.2.0 Integer 1; /* true */
SnmpMibObject enterprises.1429.79.2.2.1.17.0 Integer 1; /* true */
SnmpMibObject enterprises.1429.77.1.4.13.0 Integer 1; /* euCmLock */
SnmpMibObject enterprises.1429.78.1.7.0 Integer 2; /* twoConfigFilesDHCP */
SnmpMibObject enterprises.1429.79.2.1.1.4.0 Gauge32 8080;
SnmpMibObject enterprises.1429.77.1.7.5.0 Integer 1; /* plain */
SnmpMibObject enterprises.1429.77.1.7.6.0 String "admin";
SnmpMibObject enterprises.1429.77.1.7.7.0 String "hasloadmin";
SnmpMibObject enterprises.1429.77.1.7.3.0 String "user";
SnmpMibObject enterprises.1429.77.1.7.4.0 String "haslouser";
SnmpMibObject enterprises.1429.77.1.7.2.1.3.1.1 Integer 100;
SnmpMibObject enterprises.1429.77.1.7.2.1.3.1.2 Integer 100;
SnmpMibObject enterprises.1429.77.1.7.2.1.3.1.16 Integer 0;
SnmpMibObject enterprises.1429.77.1.7.2.1.3.1.40 Integer 0;
SnmpMibObject enterprises.1429.77.1.7.2.1.3.10.1 Integer 100;
SnmpMibObject enterprises.1429.77.1.7.2.1.3.10.2 Integer 100;
SnmpMibObject enterprises.1429.77.1.7.2.1.3.10.16 Integer 0;
SnmpMibObject enterprises.1429.77.1.7.2.1.3.10.40 Integer 0;
SnmpMibObject enterprises.1429.77.1.7.10.0 HexString 0xffffffffffffffffffffffff;
SnmpMibObject enterprises.1429.77.1.7.11.0 HexString 0xffffffffffffffffffffffff;
SnmpMibObject enterprises.1429.77.1.7.12.0 HexString 0xffffffffffffffffffffffff;
SnmpMibObject enterprises.1429.77.1.7.13.0 HexString 0xffffffffffffffffffffffff;
SnmpMibObject enterprises.1429.77.1.7.14.0 HexString 0xffffffffffffffffffffffff;
SnmpMibObject enterprises.1429.77.1.7.15.0 HexString 0xffffffffffffffffffffffff;
SnmpMibObject 1.3.6.1.4.1.1429.77.1.11.1.1.2.1 Integer 410000000;
SnmpMibObject 1.3.6.1.4.1.1429.77.1.11.1.1.2.2 Integer 416000000;
SnmpMibObject 1.3.6.1.4.1.1429.77.1.11.1.1.2.3 Integer 422000000;
SnmpMibObject 1.3.6.1.4.1.1429.77.1.11.1.1.2.4 Integer 428000000;
SnmpMibObject 1.3.6.1.4.1.1429.77.1.11.1.1.2.5 Integer 434000000;
SnmpMibObject 1.3.6.1.4.1.1429.77.1.11.1.1.2.6 Integer 440000000;
SnmpMibObject 1.3.6.1.4.1.1429.77.1.11.1.1.2.7 Integer 446000000;
SnmpMibObject 1.3.6.1.4.1.1429.77.1.11.1.1.2.8 Integer 452000000;
SnmpMibObject enterprises.1429.78.1.1001.1.0 Integer 3; /* enableSshPermanent */
SnmpMibObject enterprises.1429.78.1.1001.2.0 HexString 0x80; /* docsis */
SnmpMibObject enterprises.1429.78.1.1001.3.0 String "cisco";
SnmpMibObject enterprises.1429.78.1.1001.4.0 String "black";
SnmpMibObject enterprises.1429.79.2.1.5.1.0 Integer 1; /* true */
SnmpMibObject enterprises.1429.79.2.1.5.3.0 Integer 30; /* GMT+01:00 Warsaw */
SnmpMibObject enterprises.1429.79.2.1.5.4.0 Integer 60; /* 60" */
SnmpMibObject enterprises.1429.79.2.1.5.2.1.2.1 String "tempus1.gum.gov.pl";
SnmpMibObject enterprises.1429.79.2.1.5.2.1.2.2 String "tempus2.gum.gov.pl";
SnmpMibObject enterprises.1429.79.2.1.5.2.1.2.3 String "";
SnmpMibObject enterprises.1429.79.2.4.2.3.0 HexString 0x00; /* disable; ipsec, pptp */
SnmpMibObject enterprises.1429.79.2.4.2.2.0 HexString 0x80; /* enable; portScan, ipFlood */
SnmpMibObject enterprises.1429.79.2.2.3.6.1.0 Integer 0; /* disable */
SnmpMibObject enterprises.1429.79.2.2.1.18.0 Integer 2; /* 1 guest network */
SnmpMibObject enterprises.1429.79.2.2.1.16.0 Integer 2; /* 1 guest network */
SnmpMibObject enterprises.1429.79.2.2.1.14.0 Integer 7; /* europe */
SnmpMibObject enterprises.1429.79.2.3.2.1.13.32 Integer 0; /* disable */
SnmpMibObject .1.3.6.1.2.1.69.1.6.3.0 Integer 1; /* Default discard */
/* Permit DHCP traffic in both directions */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.1 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.1 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.1 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.1 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.1 IPAddress 0.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.1 IPAddress 0.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.1 IPAddress 0.0.0.0; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.1 IPAddress 0.0.0.0; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.12.1 Integer 67;
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.13.1 Integer 68;
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.14.1 Integer 67;
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.15.1 Integer 68;
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.1 Integer 4;/* Row status */
/* firewall */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.5 Integer 1;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.5 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.5 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.5 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.5 IPAddress 0.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.5 IPAddress 0.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.5 IPAddress 0.0.0.0; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.5 IPAddress 0.0.0.0; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.14.5 Integer 135;
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.15.5 Integer 139;
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.5 Integer 4;/* Row status */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.6 Integer 1;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.6 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.6 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.6 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.6 IPAddress 0.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.6 IPAddress 0.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.6 IPAddress 0.0.0.0; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.6 IPAddress 0.0.0.0; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.14.6 Integer 445;
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.15.6 Integer 445;
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.6 Integer 4;/* Row status */
/* Permit any traffic to/from service addresses */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.7 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.7 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.7 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.7 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.7 IPAddress 10.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.7 IPAddress 255.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.7 IPAddress 0.0.0.0; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.7 IPAddress 0.0.0.0; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.7 Integer 4;/* Row status */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.8 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.8 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.8 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.8 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.8 IPAddress 0.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.8 IPAddress 0.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.8 IPAddress 10.0.0.0; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.8 IPAddress 255.0.0.0; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.8 Integer 4;/* Row status */
/* Drop SMTP traffic */
SnmpMibObject docsDevFilterIpControl.10 Integer 2; /* accept */
SnmpMibObject docsDevFilterIpIfIndex.10 Integer 0 ;
SnmpMibObject docsDevFilterIpDirection.10 Integer 3; /* both */
SnmpMibObject docsDevFilterIpBroadcast.10 Integer 2; /* false */
SnmpMibObject docsDevFilterIpSaddr.10 IPAddress 193.151.96.0; /* calypso i inne */
SnmpMibObject docsDevFilterIpSmask.10 IPAddress 255.255.255.224;
SnmpMibObject docsDevFilterIpDaddr.10 IPAddress 0.0.0.0 ;
SnmpMibObject docsDevFilterIpDmask.10 IPAddress 0.0.0.0 ;
SnmpMibObject docsDevFilterIpStatus.10 Integer 4; /* createAndGo */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.11 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.11 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.11 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.11 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.11 IPAddress 10.249.128.1; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.11 IPAddress 255.255.255.255;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.11 IPAddress 0.0.0.0; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.11 IPAddress 0.0.0.0; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.11 Integer 4;/* Row status */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.12 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.12 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.12 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.12 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.12 IPAddress 0.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.12 IPAddress 0.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.12 IPAddress 10.249.128.1; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.12 IPAddress 255.255.255.255; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.12 Integer 4;/* Row status */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.13 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.13 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.13 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.13 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.13 IPAddress 10.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.13 IPAddress 255.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.13 IPAddress 0.0.0.0; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.13 IPAddress 0.0.0.0; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.13 Integer 4;/* Row status */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.14 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.14 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.14 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.14 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.14 IPAddress 0.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.14 IPAddress 0.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.14 IPAddress 10.0.0.0; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.14 IPAddress 255.0.0.0; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.14 Integer 4;/* Row status */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.20 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.20 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.20 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.20 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.20 IPAddress 0.0.0.0; /* SAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.20 IPAddress 0.0.0.0;/*Smask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.20 IPAddress X.Y.Z.A; /*DAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.20 IPAddress 255.255.255.255; /*DMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.20 Integer 4;/* Row status */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.3.21 Integer 2;/* IpControl/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.4.21 Integer 0;/* IpIfIndex/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.5.21 Integer 3;/* IpDirection/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.6.21 Integer 2;/* IpBroadcast/1 */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.7.21 IPAddress X.Y.Z.A; /*SAddr*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.8.21 IPAddress 255.255.255.255; /*SMask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.9.21 IPAddress 0.0.0.0; /* DAddr */
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.10.21 IPAddress 0.0.0.0;/*Dmask*/
SnmpMibObject .1.3.6.1.2.1.69.1.6.4.1.2.21 Integer 4;/* Row status */
SnmpMibObject enterprises.1429.79.2.3.2.1.1.32 Integer 2; /* router - wybor router lub bridge */
SnmpMibObject enterprises.1429.79.2.3.2.1.3.32 IPAddress 192.168.0.0 ;
SnmpMibObject enterprises.1429.79.2.3.2.1.5.32 IPAddress 255.255.255.0 ;
SnmpMibObject enterprises.1429.79.2.3.2.1.7.32 IPAddress 192.168.0.1 ;
SnmpMibObject enterprises.1429.79.2.3.3.1.2.32 IPAddress 192.168.0.10 ;
SnmpMibObject enterprises.1429.79.2.3.3.1.4.32 IPAddress 192.168.0.25 ;
SnmpMibObject enterprises.1429.79.2.2.2.1.1.2.32 Integer 1; /*enable - wl WiFi */
SnmpMibObject enterprises.1429.79.2.2.2.1.1.3.32 String "MAINSSID" ; /*SSID */
SnmpMibObject enterprises.1429.79.2.2.1.3.0 Gauge32 0; /* auto channel - wybor kanalu WiFi */
SnmpMibObject enterprises.1429.79.2.2.2.1.1.4.32 Integer 7; /* wpaWpa2Psk */
SnmpMibObject enterprises.1429.79.2.2.3.1.1.1.32 Integer 2; /* tkipPlusAes */
SnmpMibObject enterprises.1429.79.2.2.3.1.1.2.32 String "Haslodo_main_ssid" ; /* Haslo do WiFi */
UsPacketClass
ClassifierRef 1;
ServiceFlowRef 2;
RulePriority 1;
ActivationState 1;
IpPacketClassifier
IpProto 17;
SrcPortStart 2427;
SrcPortEnd 2427;
DstPortStart 2727;
DstPortEnd 2727;
UsPacketClass
ClassifierRef 2;
ServiceFlowRef 1;
RulePriority 2;
ActivationState 1;
LLCPacketClassifier
EtherType 0x030828;
DsPacketClass
ClassifierRef 3;
ServiceFlowRef 4;
RulePriority 1;
ActivationState 1;
IpPacketClassifier
IpProto 17;
SrcPortStart 2727;
SrcPortEnd 2727;
DstPortStart 2427;
DstPortEnd 2427;
UsServiceFlow
UsServiceFlowRef 1;
QosParamSetType 7;
TrafficPriority 1;
MaxRateSustained 512000000;
MinReservedRate 0;
MaxTrafficBurst 64000;
MaxConcatenatedBurst 64000;
SchedulingType 2;
IpTosOverwrite 0x0000;
UsServiceFlow
UsServiceFlowRef 2;
QosParamSetType 7;
TrafficPriority 7;
MaxRateSustained 10000;
MinReservedRate 10000;
MaxTrafficBurst 3200;
MaxConcatenatedBurst 3200;
SchedulingType 2;
RequestOrTxPolicy 0x00000060;
DsServiceFlow
DsServiceFlowRef 3;
QosParamSetType 7;
TrafficPriority 1;
MaxTrafficBurst 128000;
MinReservedRate 0;
DsServiceFlow
DsServiceFlowRef 4;
QosParamSetType 7;
TrafficPriority 7;
SwUpgradeFilename "epc3925-firmware.p7b";
SwUpgradeServer 10.0.0.230;
MfgCVCData
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;
MfgCVCData
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;
MfgCVCData
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;
MfgCVCData
0x8da2c40a876e8befe521eb2369cb171d687f67158417f1833d0b168d74128ee80090a6c45d8c8baa227237b18c61137373628339bcbacae6455defe25338e1ceb23e37ebf21e148949c0d4763b3c39e337a99aaf311175af4823eb3f6370de01bc5d96f0cffa054d6e55034ff07adf22ea55a3fd6e176b36a55ffe300af14301f67f0581626f3f223bb916;
DocsisTwoEnable 1;
/* CmMic d46e60daf3aa396f1577c819bc20ec9a; */
/* CmtsMic 617397a9a9ab61a3d4ddc58653bc3fe0; */
/*EndOfDataMkr*/
/* Pad */
02-24-2015 09:34 AM
This issue I solved by myself. This was due to wrong configuration of the Web pages permissions.
We can close this case.
GC
