Errors in Kernel logs on my RV120W
kaudik12.
Hello, after succesfully update to version 1.0.5.6, I have errors in my log.
I made a factory reset after update and manualy set everything.
I have cable internet connection, DHCP server in Cisco, use wifi and I have a few firewall and forwarding rules.
I tried to uncheck all in Firewall settings on Attack prevention and after restart is everything the same.
There are a lot the same logs and there are no free memory for next records.
Everything I set in my log setting is Kernel Errors logging - there is only one way to log dropped or allowed connections.
My log is here:
Mon Oct 14 17:08:53 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:09:28 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 3 messages suppressed.
Mon Oct 14 17:09:28 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:09:33 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:09:58 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:10:08 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:10:18 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:10:28 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:10:33 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:10:43 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:10:48 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:10:58 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:11:03 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:11:04 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:11:14 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:11:24 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:11:29 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:11:34 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:11:44 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:11:54 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:12:04 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:12:14 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:12:19 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:12:29 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:12:34 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:12:39 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:12:49 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:12:59 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:13:09 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:13:14 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:13:19 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 5 messages suppressed.
Mon Oct 14 17:13:19 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:13:29 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:13:39 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:13:49 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:13:59 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:14:09 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:14:19 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:19:55 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:20:00 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:20:05 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:20:10 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 487 messages suppressed.
Mon Oct 14 17:20:10 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:22:05 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 130 messages suppressed.
Mon Oct 14 17:22:05 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:23:15 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:29:30 2013(EET) [Kaudigate][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Oct 14 17:33:05 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 4 messages suppressed.
Mon Oct 14 17:33:05 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:34:35 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:35:35 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 67 messages suppressed.
Mon Oct 14 17:35:35 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:39:30 2013(EET) [Kaudigate][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Oct 14 17:48:41 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:48:41 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 2 messages suppressed.
Mon Oct 14 17:49:06 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 10 messages suppressed.
Mon Oct 14 17:49:06 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:49:41 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:49:46 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:49:56 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:50:01 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:51:36 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:53:16 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:54:56 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 5 messages suppressed.
Mon Oct 14 17:54:56 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:57:01 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:57:06 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:57:07 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:57:42 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:57:47 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 17:58:17 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 18:01:22 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 5 messages suppressed.
Mon Oct 14 18:01:22 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 18:03:22 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 18:04:17 2013(EET) [Kaudigate][Kernel][KERNEL] printk: 4 messages suppressed.
Mon Oct 14 18:04:17 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 18:04:37 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Oct 14 18:05:22 2013(EET) [Kaudigate][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Oct 14 18:07:32 2013(EET) [Kaudigate][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
jeffrrod
Level 4
Level 4
Dear Jan,
Thank you for reaching the Small Business Support Community.
I would think is a memory failure but anyway, and since you have already done the possible troubleshooting and there are no known issues about this, I suggest you to contact the Small Business Support Center to figure this out;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is any further assistance I may help you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
