03-20-2013 02:23 AM
Good morning!
I am trying to set up a gateway to gateway VPN connection between a RV042G (central site) and a RV110W (newest firmware) which is used for presentation purposes on various customer's sites. The RV042G has a static IP. The RV110W has different IPs, depending on where it is used.
Basic VPN settings are clear to me (we have another VPN between two RV042G with static IPs). I set up the VPN connection on the RV042G wth the following settings for "Remote Group Setup":
Remote Security Gateway Type : IP + Domain Name (FQDN) Authentication
IP by DNS resolved: mydomain.no-ip.org
Domain Name: router12345
The value "router12345" is what I have configured in the RV110W as "Host name" in the network settings.
This configuration does not work so I am obviously doing something wrong. Do I have to use "router12345.mydomain.local" instead if I configured "mydomain.local" as the domain name in the RV110Ws network settings? For my tests the RV110W has a WAN-IP of 192.168.178.100 because it is located behind a DSL-Router. The external IP of this DSL-router is 178.0.x.x. The resolved IP from mydomain.no-ip-org is 192.168.178.100 but when I look in the RV042G log I see the requests coming withg the external IP (178.0.x.x). Is this the problem? The last message I see in the log is "no connection has been authorized with policy=PSK".
Or can I use "IP + Email Address (USER FQDN) Authentication" instead (where can I enter this email address in the RV110W?). Or do I have to use "Dynamic IP"?
Thank you very much in advance!
Christian Steffen
03-25-2013 08:13 AM
Good morning
Hi Christian, thanks for using our forum, my name is Johnnatan and I am part of the Small business Support community. I´ve seen yuor problem and I found some docuemnts about it:
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=304
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=3011
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=568
I hope you find these documents will be useful,
*Please mark the question as Answered or rate it so other users can benefit from it*
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
