How to configure multiple HTTP port forwards to unique IP addr?
askewdodge
When i try to set two HTTP single port forwarding rules for distinct IP addresses inside my LAN, i get a message that the rules are identical when they're not.  Below is the specific setup i'm trying to put in effect:
rule 1 - HTTP forward port 3001 to internal port 3001 to IP addr 192.168.0.300
rule 2 - HTTP forward port 3002 to internal port 3002 to IP addr 192.168.0.301
I can activate one of these rules, routing the traffic correctly, but when i try to activate both i get the error message.  any help out there?
thanks
ra
David Carr
Level 6
Level 6
Do you have the same name for both of these rules, typically i see that when your naming the rules and one has the same name as the other.
