How to create ACL to permit TCP outside traffic into a specific host in my network
diegog
Hello everybody,
Actually what I want is permit TCP outside traffic into a specific host in my network using 80 port.
Can it be like this?
access-list 101 permit tcp any host 10.0.x.x eq 80
ip nat inside source list 101 interface g8 overload
May anybody help me with this?
Seb Rupik
Hi there,
Try this:
ip nat inside source static tcp 10.0.x.x 80 interface gi8 80
cheers,
Seb.
7 Replies 7
Seb Rupik
Hi there,
Try this:
cheers,
Seb.
Thanks for your feedback, I already tried this but doesn`t work and I was
wondering if it is because I have already created an ACL to allow traffic
in my network.
Thanks again
in my network.
Thanks again
Can you share the running config of your switch?
This is the config of my router
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address xx.xx.xx.xx 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet9
no ip address
shutdown
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface Vlan1
ip address 192.168.x.x 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface GigabitEthernet8 overload
ip nat inside source static tcp 192.168.x.x xxxx interface GigabitEthernet8 xxxx
ip nat inside source static udp 192.168.x.x xxxx interface GigabitEthernet8 xxxx
ip nat inside source static udp 10.x.x.x xxxx interface GigabitEthernet8 xxxx
ip nat inside source static tcp 10.x.x.x 80 interface GigabitEthernet8 80
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.xx
ip route 10.x.x.x 255.255.255.0 192.168.x.x permanent
access-list 10 permit 192.168.x.x 0.0.0.255
access-list 10 permit 10.x.x.x 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
Seb any idea?
I already fix it!
Thanks anyway
