How to disable DHCP on SRP546W
jdoldridge
Hi all, I am currently configuring my new SRP546W on my network and I need to disable DHCP I dont want clashes with IP's from my current DHCP server on my network.
Just wondered if somebody would be able to shed some light on my situation.
Many Thanks
jdoldridge
Andrew Hickman
Hi Joshua,
Just go in to the VLAN configuration and change the address setting from DHCP server to static or DHCP.  Static would probably make the most sense in this case.
Cheers
Andy
