How to setup RV110W just to act as Wifi hotspot?
Enzo75000
I've to setup RV110W router as a simple Wifi hotspot in a company network and this Wifi hotspot has to allow traffic to all internal LAN (very simple LAN with few workstation and one server) and also to Internet via our gateway. I know this product isn't really designed for that... but I've to do so.
LAN is managed by Windows DHCP server and I've Internet acces through Firewall.
I think I've to connect RV110W to the company LAN with the RV110W WAN interface.
I want the Wifi IP address to be in the same IP range than the LAN to allow Wifi clients to access our internal server but RV110W doesn't accept this.
Or do I've to ignore the WAN interface and deal with only the RV110W LAN interface?
Does someone can help?
regards
Te-Kai Liu
Level 7
Level 7
If you ignore the WAN port of RV110W and plug one of its LAN port into your company's LAN, all the WiFi clients will get IP address from the DHCP Server of your company's LAN.
