01-15-2017 07:55 PM
I have a Cisco RV325 and I am connecting it to a wireless access point HP M330. The AP SSID can be configured with different VLAN (e.g. Internal WiFi, Guest WiFi). How do I configure multiple VLAN in a single port of RV325? I can do it in a managed switch called hybrid port, but I am unsure how in the RV325.
Solved! Go to Solution.
02-02-2017 06:46 PM
RV325 allow user to configure multiple vlan on the same port, use LAN1 for example. You can adjust the settings to suit your needs
LAN1 Untagged VID1 - all packets that do not carry the vlan tag will get VLAN1's ip pool.
LAN1 tagged VID25/100/4 - packets must be carry the labels 25/100/4 to obtain the corresponding VLAN IP pool.
VLANID Des InterVLAN DeviceManage LAN1 LAN2 LAN3
1 Default Disabled Enabled Untagged Untagged Untagged
25 Guest Disabled Disabled Tagged Tagged Tagged
100 Voice Disabled Disabled Tagged Tagged Tagged
4 4 Disabled Enabled Tagged Tagged Tagged
02-02-2017 06:46 PM
