Hybrid VLAN Port RV325
sg.it
I have a Cisco RV325 and I am connecting it to a wireless access point HP M330. The AP SSID can be configured with different VLAN (e.g. Internal WiFi, Guest WiFi). How do I configure multiple VLAN in a single port of RV325? I can do it in a managed switch called hybrid port, but I am unsure how in the RV325.
Ami Xiao
RV325 allow user to configure multiple vlan on the same port, use LAN1 for example. You can adjust the settings to suit your needs
LAN1 Untagged VID1 - all packets that do not carry the vlan tag will get VLAN1's ip pool.
LAN1 tagged VID25/100/4 - packets must be carry the labels 25/100/4 to obtain the corresponding VLAN IP pool.
VLANID Des         InterVLAN   DeviceManage  LAN1                 LAN2                  LAN3
1            Default    Disabled      Enabled             Untagged          Untagged           Untagged
25          Guest      Disabled      Disabled            Tagged              Tagged               Tagged
100        Voice       Disabled      Disabled            Tagged              Tagged               Tagged
4            4              Disabled      Enabled             Tagged              Tagged               Tagged
Ami Xiao
