IKEv2 remote access from iPhone
train_wreck
Can someone tell me what I'm doing wrong here? I am trying to configure certificate-based IKEv2 remote access VPN on a RV340W with new firmware 1.0.02.16. Here are the settings on the RV340W:
Here are the settings from the iPhone:
Here is the log of the failure connecting:
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] IKE_SA (unnamed)[1] state change: CONNECTING => DESTROYING
2019-01-03T18:59:51-06:00 <info>charon: 08[NET] sending packet: from CISCO_IPADDRESS[4500] to IPHONE_IPADDRESS[5174] (80 bytes)
2019-01-03T18:59:51-06:00 <info>charon: 08[ENC] generating IKE_AUTH response 1 [ N(AUTH_FAILED) ]
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] peer supports MOBIKE
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] received ESP_TFC_PADDING_NOT_SUPPORTED, not using ESPv3 TFC padding
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] processing (25) attribute
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] processing INTERNAL_IP6_DNS attribute
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] processing INTERNAL_IP6_DHCP attribute
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] processing INTERNAL_IP6_ADDRESS attribute
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] processing INTERNAL_IP4_NETMASK attribute
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] processing INTERNAL_IP4_DNS attribute
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] processing INTERNAL_IP4_DHCP attribute
2019-01-03T18:59:51-06:00 <info>charon: 08[IKE] processing INTERNAL_IP4_ADDRESS attribute
2019-01-03T18:59:51-06:00 <info>charon: 08[CFG] no matching peer config found
2019-01-03T18:59:51-06:00 <info>charon: 08[CFG] looking for peer configs matching CISCO_IPADDRESS[CN=RV340.pLAN9.co]...IPHONE_IPADDRESS[OU=IPsec, CN=pLAN9-iPhone]
2019-01-03T18:59:51-06:00 <info>charon: 08[ENC] parsed IKE_AUTH request 1 [ IDi N(INIT_CONTACT) N(MOBIKE_SUP) IDr CPRQ(ADDR DHCP DNS MASK ADDR6 DHCP6 DNS6 (25)) N(ESP_TFC_PAD_N) N(NON_FIRST_FRAG) SA TSi TSr ]
2019-01-03T18:59:51-06:00 <info>charon: 08[ENC] unknown attribute type (25)
2019-01-03T18:59:51-06:00 <info>charon: 08[NET] received packet: from IPHONE_IPADDRESS[5174] to CISCO_IPADDRESS[4500] (528 bytes)
2019-01-03T18:59:51-06:00 <info>charon: 06[NET] sending packet: from CISCO_IPADDRESS[500] to IPHONE_IPADDRESS[5159] (473 bytes)
2019-01-03T18:59:51-06:00 <info>charon: 06[ENC] generating IKE_SA_INIT response 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) CERTREQ N(FRAG_SUP) N(MULT_AUTH) ]
2019-01-03T18:59:51-06:00 <info>charon: 06[IKE] sending cert request for CN=pLAN9 CA 2019-2021
2019-01-03T18:59:51-06:00 <info>charon: 06[IKE] remote host is behind NAT
2019-01-03T18:59:51-06:00 <info>charon: 06[IKE] IKE_SA (unnamed)[1] state change: CREATED => CONNECTING
2019-01-03T18:59:51-06:00 <info>charon: Last message '06[IKE] 174.196.134.' repeated 1 times, supressed by syslog-ng on TestRV340W
2019-01-03T18:59:51-06:00 <info>charon: 06[IKE] IPHONE_IPADDRESS is initiating an IKE_SA
2019-01-03T18:59:51-06:00 <info>charon: 06[ENC] parsed IKE_SA_INIT request 0 [ SA KE No N(REDIR_SUP) N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) ]
2019-01-03T18:59:51-06:00 <info>charon: 06[NET] received packet: from IPHONE_IPADDRESS[5159] to CISCO_IPADDRESS[500] (604 bytes)
How do I proceed from here?
mipopov
Happy New 2019 Year!
Try to create custom IPSec profile and choose it from drop down menu.
What happens?
Hope it helps
Cheers,
Mike
Not to be rude, but did you even look at the pictures in my post? I have already created a custom ipsec profile, as the drop-down box clearly shows. Here is the screenshot of the settings of the profile:
