Inquiry Cisco RV345P
2020-12-09T09:00:14+06:30 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2020-12-09T09:12:14+06:30 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2020-12-09T09:24:14+06:30 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2020-12-09T09:30:14+06:30 <error>Webfilter: Last message 'BCAP server error (7' repeated 1 times, supressed by syslog-ng on routerED82E6
2020-12-09T09:30:14+06:30 <error>Webfilter: BCAP server error (704): Invalid major or minor version
27 Replies 27
marce1000
          - Use the latest firmware available for the RV.
 M.
I have already the latest version of the firmware. Thank you
I also face the same issue in RV340. I'm using the latest firmware - 1.0.03.20
Martin Aleksandrov
Hi Benjie,
Do you have the security license activated and using dynamic web filtering?
Martin
Hi Martin,
I am currently using the evaluation mode and it is not yet expired.
I have the same issue, I do have the security license fully activated, this didn't happen before, but I recently setup a backup WAN on WAN 2 and it's now throwing these warnings regularly.
WSK
I am seeing this as well recently.  The logs are appearing every few minutes.  Also have active security license.
RV345 VPN Router having firmware version 1.0.03.20 and signature version 2.0.0.0015 and also have an active security license having the same issues described. Here is a breakdown including dates of my logs starting with the oldest first.
5 Lines worth of -> 2021-01-11T06:25:54-08:00 <warning>kernel: [5776214.983379] FIREWALL SYN-FLOOD:IN=eth2 OUT
34 LInes of webfilter messages
10 Lines worth of -> 2021-01-18T12:47:30-08:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
5 Lines worth of -> 2021-01-19T05:23:23-08:00 <warning>kernel: [6463664.482667] FIREWALL SYN-FLOOD
Then 1150 lines worth of BCAP server errors and 38 lines of other messages.
I had gone through the process of adding blacklisted sites from solar winds with the aide of CISCO (not tak) support, and believe the 10 attempts in red are most likely some form of denial of service attack.
If @1st you don't succeed, then try something else and remember the best design is the simplest one that works.
JohnToles07774
Hundreds of this same error message daily with an RV345 VPN using WAN 1 and WAN 2, latest firmware and signature, no licenses active.
YIJang19667
I also have faced same messages from 2021-02-02 ~.
model: RV340
f/w verson: 1.0.03.20
signature version: 2.0.0.0015
license: purchased for 1 year license and not expired yet
web filter: not used
2021-02-02T04:20:32+09:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2021-02-02T04:26:32+09:00 <error>Webfilter: Last message 'BCAP server error (7' repeated 1 times, supressed by syslog-ng on miroRouter
2021-02-02T04:26:32+09:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2021-02-02T04:32:32+09:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2021-02-02T04:50:32+09:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2021-02-02T05:02:32+09:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2021-02-02T05:08:32+09:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2021-02-02T05:20:32+09:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
2021-02-02T05:38:32+09:00 <error>Webfilter: BCAP server error (704): Invalid major or minor version
Hi all,
Please raise a case with the Cisco STAC so they can investigate and eventually escalate the issue.
Martin
Celvis
i also have this error message, active Security-License via smart licensing and Umbrella as DNS (not registered as device), web filtering is disabled in security settings.
2021-Feb-21, 10:26:28 CET error web-filter Webfilter: BCAP server error (704): Invalid major or minor version
Every 6 minutes this error message appears. Reboot did nothing. Firmware is 1.0.03.20 Signature file is 2.0.0.0015. This started approximately a week ago.
simon.pep1
Have this problem too, starting a few days ago.
I have a RV340 router, running current Firmware, with web filtering off as not using the Security features outside basic NAT and Firewall.
No changes made to the Router setting since the last Firmware update last September.
I have the same issue. I have no license and therefore webfilter is disabled, but it is still trying to update itself.
Zeile 6566: 2021-02-21 16:13:47 User.Error IP 1 2021-02-21T16:13:47+01:00 home Webfilter - - [meta sequenceId="100783"] BCAP server error (704): Invalid major or minor version
Zeile 6886: 2021-02-21 16:19:47 User.Error IP 1 2021-02-21T16:19:47+01:00 home Webfilter - - [meta sequenceId="101101"] BCAP server error (704): Invalid major or minor version
Zeile 6900: 2021-02-21 16:25:47 User.Error IP 1 2021-02-21T16:25:47+01:00 home Webfilter - - [meta sequenceId="101113"] BCAP server error (704): Invalid major or minor version
Zeile 6902: 2021-02-21 16:26:11 User.Error IP 1 2021-02-21T16:26:11+01:00 home Webfilter - - [meta sequenceId="101115"] BCAP server error (704): Invalid major or minor version
Zeile 6910: 2021-02-21 16:31:47 User.Error IP 1 2021-02-21T16:31:47+01:00 home Webfilter - - [meta sequenceId="101119"] BCAP server error (704): Invalid major or minor version
Zeile 6927: 2021-02-21 16:37:47 User.Error IP 1 2021-02-21T16:37:47+01:00 home Webfilter - - [meta sequenceId="101134"] BCAP server error (704): Invalid major or minor version
Zeile 6940: 2021-02-21 16:41:11 User.Error IP 1 2021-02-21T16:41:11+01:00 home Webfilter - - [meta sequenceId="101145"] BCAP server error (704): Invalid major or minor version
Zeile 6953: 2021-02-21 16:43:47 User.Error IP 1 2021-02-21T16:43:47+01:00 home Webfilter - - [meta sequenceId="101158"] BCAP server error (704): Invalid major or minor version
Zeile 6970: 2021-02-21 16:49:47 User.Error IP 1 2021-02-21T16:49:47+01:00 home Webfilter - - [meta sequenceId="101171"] BCAP server error (704): Invalid major or minor version
Zeile 7111: 2021-02-21 16:55:47 User.Error IP 1 2021-02-21T16:55:47+01:00 home Webfilter - - [meta sequenceId="101310"] BCAP server error (704): Invalid major or minor version
Zeile 7132: 2021-02-21 16:56:12 User.Error IP 1 2021-02-21T16:56:12+01:00 home Webfilter - - [meta sequenceId="101331"] BCAP server error (704): Invalid major or minor version
Zeile 7172: 2021-02-21 17:01:47 User.Error IP 1 2021-02-21T17:01:47+01:00 home Webfilter - - [meta sequenceId="101369"] BCAP server error (704): Invalid major or minor version
Zeile 7206: 2021-02-21 17:07:47 User.Error IP 1 2021-02-21T17:07:47+01:00 home Webfilter - - [meta sequenceId="101402"] BCAP server error (704): Invalid major or minor version
Zeile 7232: 2021-02-21 17:11:12 User.Error IP 1 2021-02-21T17:11:12+01:00 home Webfilter - - [meta sequenceId="101426"] BCAP server error (704): Invalid major or minor version
Zeile 7292: 2021-02-21 17:13:47 User.Error IP 1 2021-02-21T17:13:47+01:00 home Webfilter - - [meta sequenceId="101484"] BCAP server error (704): Invalid major or minor version
