IPSec SA Not Established 2 ROUTER RV110W
mahjoub.zeroual
Hello ,
I make a vpn site-to-site IPSEC tunnel between 2 RV110W
the above ,you will find the configuration
Site1
Site 2
always the same message
Best Regards
Mehdi Boukraa
Hi Zeroual,
the configuration of the security it looks fine but can i have informations about the both local network (local network and destination local network )
Mehdi
Thnks for your reponse
Local Site1:192.168.1.0
Local Site 2:192.168.3.0
Can you please enable the log under administration and on view logs clear all the logs and try to connect and share the logs or you can send to me mboukraa@cisco.com
mehdi
I am having same problem too with expressvpn, can you please help?
I think I am using the wrong ip addresses as this is what my system summery says :-
IPv4 Configuration
LAN IP:1.2.3.4DNS 1:192.168.5.1
WAN IP:192.168.5.3 DNS 2:
Gateway:192.168.5.1
