IPSec SA Not Established
carlsonrb
Beginner
Beginner
Using RV110W Wireless-N VPN Firewall Routers on both ends. On the IPSec Connection Status page why am I getting the State; "IPSec SA Not Established" when nothing that I'm aware of has changed in the settings?
Ingrid Aragon
Beginner
Beginner
Hello Richard, I am one of the engineers from the Small Business team.
I would recommend making sure of:
  • Have the latest firmware version installed on both routers (version 1.2.1.7)
  • Make sure that ISP modem is setup as bridge mode (or that Public IP address in showed on the WAN interface of the routers).
  • The LANs cannot be duplicated on the routers.
  • Make sure that all configuration between the two routers is matching.
Confirm that you are meeting the above recommendations and if the issue persists.
Why should I rate content?
You'll be ensuring that people who generously share their expertise are properly acknowledged. As posts are rated, the value of those ratings are accumulated as "points" and summarized on the Member Profile page and on each member's Preferences page.
Recognize Your Peers
