My vendor said it should be compatible. I set up it up, triple checked, the AT&T modem works fine, but when I plug the RV134W in, it eventually goes red, saying there is no DSL.
I have programmed it manually with IPs assigned to it. That didn't work. I ran the wizard and let it detect it. I have all the correct account info. It is using PPPoE. The Wizard says it detects a DSL connection, but then indicator goes red and says there isn't one.
The account is an AT&T Business HSI Elite-S. When simply look for compatible Modems/Routers I never do see the RV134W.
Ideas?
