Issue with RV220W
man1k1234
I have following issue with RV220W - the router seems to be dropping parts of traffic coming through it. The unit is brand new, the firewall is turned off, there are about 20 computers and 15 VOIP phones connected to it via Zyxel GS1910-48; all IPs are set to static DHCP records, in the last 3 hours the router rebooted about 3 times, then I turned on the login. The router is producing insane number of warnings, as you may see from the log attached. I found this thread https://supportforums.cisco.com/thread/212247 but no answer regarding this issue. Can you please give me advice how to solve this issue?
Wed May 15 13:03:10 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:10 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:15 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:15 2013(GMT) [rv220w][Kernel][KERNEL] printk: 2 messages suppressed.
Wed May 15 13:03:15 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:16 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:16 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:16 2013(GMT) [rv220w][Kernel][KERNEL] printk: 10 messages suppressed.
Wed May 15 13:03:21 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:21 2013(GMT) [rv220w][Kernel][KERNEL] printk: 4 messages suppressed.
Wed May 15 13:03:21 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:22 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:22 2013(GMT) [rv220w][Kernel][KERNEL] printk: 1 messages suppressed.
Wed May 15 13:03:22 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:27 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:27 2013(GMT) [rv220w][Kernel][KERNEL] printk: 2 messages suppressed.
Wed May 15 13:03:27 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:32 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:32 2013(GMT) [rv220w][Kernel][KERNEL] printk: 2 messages suppressed.
Wed May 15 13:03:32 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:33 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:33 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:33 2013(GMT) [rv220w][Kernel][KERNEL] printk: 7 messages suppressed.
Wed May 15 13:03:34 2013(GMT) [rv220w][Kernel][KERNEL] printk: 11 messages suppressed.
Wed May 15 13:03:34 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:34 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:39 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:39 2013(GMT) [rv220w][Kernel][KERNEL] printk: 2 messages suppressed.
Wed May 15 13:03:39 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:44 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:44 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:54 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:54 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:03:55 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Wed May 15 13:03:55 2013(GMT) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Wed May 15 13:02:31 2013(GMT) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
2011-01-01 00:00:41: [rv220w][IKE] INFO:  IKE started
5 Replies 5
man1k1234
Few more details - Wireless is completely shut down, all traffic is coming via ethernet ports. Full logging is turned on, only warnings occur, with an insane rate of about 1000 warnings/hour. Will keep updating once the router crashes again.
Hi Martin,
what firmware release are you running?
David
1.0.4.17
This is the error log after last crash:
Sat Jan  1 00:02:10 2011(GMT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Sat Jan  1 00:02:18 2011(GMT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Fri May 17 11:43:03 2013(GMT) [rv220w][System][FIREWALL] fwPPTPGenericRules.c: inet_aton failed
Fri May 17 11:43:04 2013(GMT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Fri May 17 11:43:09 2013(GMT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Fri May 17 11:43:24 2013(GMT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Fri May 17 11:43:29 2013(GMT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Fri May 17 11:43:43 2013(GMT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Fri May 17 11:43:44 2013(GMT) [rv220w][System][PLATFORM] [BONJOUR_ERROR]: DNSServiceProcessResult returned -65537 stopping listen to mdnsd
Fri May 17 11:43:46 2013(GMT) [rv220w][System][PLATFORM] [BONJOUR_ERROR]: Signal Sent to bonjourClient Failed
Fri May 17 11:43:47 2013(GMT) [rv220w][System][PLATFORM] [BONJOUR_ERROR]: DNSServiceProcessResult returned -65537 stopping listen to mdnsd
Fri May 17 11:43:50 2013(GMT) [rv220w][System][PLATFORM] [BONJOUR_ERROR]: Signal Sent to bonjourClient Failed
Fri May 17 11:44:18 2013(GMT) [rv220w][System][FIREWALL] fwPPTPGenericRules.c: inet_aton failed
And warning log:
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] CVMSEG size: 2 cache lines (256 bytes)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] CPU revision is: 000d0601
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Determined physical RAM map:
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL]  memory: 0000000007800000 @ 0000000000700000 (usable)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Built 1 zonelists.  Total pages: 30276
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Primary instruction cache 32kB, virtually tagged, 4 way, 64 sets, linesize 128 bytes.
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Primary data cache 16kB, 64-way, 2 sets, linesize 128 bytes.
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] PID hash table entries: 512 (order: 9, 4096 bytes)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Using 400.000 MHz high precision timer.
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Inode-cache hash table entries: 8192 (order: 4, 65536 bytes)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Calibrating delay using timer specific routine.. 800.39 BogoMIPS (lpj=1600784)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Mount-cache hash table entries: 256
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Checking for the multiply/shift bug... no.
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Checking for the daddi bug... no.
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Checking for the daddiu bug... no.
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Enabling Octeon big bar support
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] PCI Status: PCI 32-bit
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] IP route cache hash table entries: 1024 (order: 1, 8192 bytes)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] TCP established hash table entries: 4096 (order: 4, 65536 bytes)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] /proc/octeon_perf: Octeon performace counter interface loaded
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Total HugeTLB memory allocated, 0
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] RAMDISK driver initialized: 1 RAM disks of 500000K size 1024 blocksize
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] GACT probability NOT on
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] Mirror/redirect action on
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] u32 classifier
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL]     Performance counters on
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL]     Actions configured
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] nf_conntrack version 0.5.0 (480 buckets, 3840 max)
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] ip_tables: (C) 2000-2006 Netfilter Core Team
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] netfilter PSD loaded - (c) astaro AG
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] ipt_time loading
Sat Jan  1 00:01:45 2011(GMT) [rv220w][Kernel][KERNEL] ip6_tables: (C) 2000-2006 Netfilter Core Team
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] ip6t_time loading
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Bootbus flash: Setting flash for 32MB flash at 0x1dc00000
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL]  Amd/Fujitsu Extended Query Table at 0x0040
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] phys_mapped_flash: CFI does not contain boot bank location. Assuming top.
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] BOOT BUS: Address decode error
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] cavium-ethernet: Cavium Networks Octeon SDK version 1.7.3, build 264
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Register the sysctl for hardware offload succeed 0
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Register the sysctl for flow cache succeed
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Register the sysctl for brcm Tag succeed
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Register the sysctl for vlan enabled succeed
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Pool 0 size 2048 No 1024
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Pool 1 size 128 No 1024
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Pool 3 size 128 No 10240
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] global cache allocation start 0
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Ipforward global cache allocation sucessfull
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl for IMP port status
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl for 802.1x enabled port
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl for blocking non EAP packets status
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Interface 0 has 3 ports (RGMII)
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] 999
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] 1002
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] 1040
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] 1042
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] port ko 0
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] port ko 1
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] port ko 2
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] led module init...
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] umi: module license 'unspecified' taints kernel.
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] eth0: 1000 Mbps Full duplex, port  0, queue  0
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] eth1: 1000 Mbps Full duplex, port  1, queue  1
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] PF_key: Initialized Security Policy Database.
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] IPsec: Initialized Security Association Processing.
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] BUG: at kernel/softirq.c:138 local_bh_enable()
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Call Trace:[][][][][][][][][][][][
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Intializing the 8021P-DSCP Remark Module
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl for _8021p task IMP port<6>registering backend engine with xlr8Nat framework
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl reboot status
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] PCI: Enabling device 0000:00:03.0 (0000 -> 0002)
Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] vap0: Broadcom BCM432b 802.11 Wireless Controller 5.60.120.9
Sat Jan  1 00:01:48 2011(GMT) [rv220w][System][PLATFORM] IPv6 not configured on the interface
Also, is it normal that the web interface is so slow? I wait approximately 10 secs before each page loads, no matter which PC I access it from and which browser I use?
Thanks for advice!
The part after
"And warning log:"
is partly a standard bootlog
After
"Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] umi: module license 'unspecified' taints"
it's no longer standard till "Sat Jan  1 00:01:46 2011(GMT) [rv220w][Kernel][KERNEL] Intializing the 8021P-DSCP Remark Module"
Re:
Thanks for advice!
some pages take a few seconds when they need to build data (e.g. local hosts) but most molad within 1 or 2 secs.
David
