K5161 dongle on RV130
reflexivo
I'm wondering if anyone knows if the Vodafone K5161 or HUAWEI Balong B711 4G dongles will work in either the RV130 or RV320 routers? There are some Vodafone/Huawei dongles listed in the support documents but not those particular models.
Martin Aleksandrov
Most probably those dongles won't work with the RV130 and RV320. Supported models you can find in the following links:
RV130:
https://community.cisco.com/t5/small-business-support-documents/dongle-support-for-the-rv130-and-rv130w-multifunction-vpn/ta-p/3172875
RV320:
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/USB_Compatibility_Matrix/Rv320x_compatibility_matrix.pdf
Martin
