Need a how to: RV042 second DHCP
lukyluke17
Hy all,
I have a CISCO RV042 in a network with 2 subnets 192.168.1.x and 192.168.2.x and I want multiple DHCP on both subnets. How can I do that?
If I use a second router for the second subnet (192.168.2.x) to use its DHCP. The bandwith management will work? Do I need port VLANs?
The network is like this:
The RV042 is the main router thru it we acces the internet, it also suplies DHCP 192.168.1.x, I enabled multiple subnet for 192.168.2.x.
The reason I want 2 subnets is beacause I have 2 acces points for wireless clients and I want to use rate control on WAN with bandwith management from RV042 too give wired clients more bandwith than wireless clients.
I know that RV042 doesn't supply multiple dhcp like RV180,but I needed dual WAN.
Thank You
paolo bevilacqua
Wrong forum, post in "Small Business routers". You can move your posting with the Actions panel on the right.
paolo bevilacqua
