Hi Ronald, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. I will be glad to help you with your configuration. Let me check if I understood, you want to connect VPN site-to-site between RV180 and ASA5505 enterprise, it is possible, you need to configure both routers with the same attributes (Encriptation, Authentication, Group and both address information need to be crossed)
I found information, it could be useful to your configuration, http://www.cisco.com/en/US/docs/routers/csbr/rv180w/administration/guide/rv180w_admin.pdf in page 106 and few configuration steps to configure your RV180, http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2264, also set your configuration in main mode, all this information is regard to RV180 VPN configuration, to find support for your enterprise device I advise you to port your question here https://supportforums.cisco.com/community/netpro/security/vpn
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it”
Greetings,
