Need to block rv110w access to router from wan
mcoppola58
Is there any way to block access to the router logon page from the wan?  By simply going to the router's external WAN IP, the cisco logon screen shows up?  I really think this not that safe and want to block it from showing up.  I have looked at all the settings and don't seem to be able to find something that will keep that from happening.
M
johschaf
Level 4
Level 4
Hello Michael,
You can disable remote management via Firewall --> Basic Settings. In the basis settings page there should be an option to enable remote managment. Make sure that option is unchecked.
Hope this helps.
-john
