Need to find multiple SSID/VLAN configuration procedure
robmallicoat
I just purchased a WRVS4400N v2 and it works fine for my one main SSID to my lab.  I want to set it up so that i have a second SSID for guests, giving it its own subnet, dhcp and then routing it out to the internet with no access to the lab subnet or lab ssid
i have setup two SSID (SSID1 and SSID2)
I have setup a second VLAN (VLAN2)
I have associated SSID2 with VLAN2
I have disabled DHCP for VLAN since I already have DHCP running on Windows 2008 server
I have setup the DHCP scopy for VLAN2 as 192.168.2.1 and preset DNS for my ISP (Comcast)
I can see both SSID1 and SSID2 and connect to both BUT I am getting DHCP ip from the windows 2008 server still...
what did i miss?
thx
rshao
Pls try to re-post this to the following support commuity.  THere are more WRVS experts there who can better answer this for you.
https://supportforums.cisco.com/community/netpro/small-business/routers
Richard
Question moved from the small business security area to the small business router area - Cindy Toy, Small Business Support Community Manager
Tiya Rabb
Do you have Inter-VLAN routing disabled on the router?
