Dear Michael,
Thank you for reaching the Small Business Support Community.
I would first suggest you to upgrade to the latest firmware release version 1.0.4.10;
http://software.cisco.com/download/release.html?mdfid=282981372&softwareid=282487380&release=1.0.4.10
If nmap still shows the port opened, I then suggest you to disable the remote management to determine if this is the root of the problem, then contact the Small Business Support Center to have a TAC engineer figure this out;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is anything I may assist you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
