openvpn connection issue to rv160
bilvi
I can connect and ping the vlan 1 IP address, but I can not ping or access anything else on the network.
Network is 192.168.1.X openvpn I get 10.1.4.2 assigned on the client.
Seems like a routing issue but I thought as long as I have Tunnel Mode > Split > 192.168.1.0 > 255.255.255.0
VLan 1 is a static ip of 192.168.1.132/24  255.255.255.0 DHCP relay 192.168.1.74
Any Suggestions
6 Replies 6
balaji.bandi
what do you mean by anything else in the network ?  Does VLAN 1 IP address mean you are able to ping 192.168.1.132?
BB
correct I can ping 192.168.1.132 from the client and get a reply but can not get anywhere else.   On the router it self I can ping the other places I want to get at and get a response. I have a internal webserver at 192.168.1.164 that the router can ping but the client can not.
bilvi
I assume it has to do with the routing as the RV160 is not the default gateway?
ok trying to understand the issue, before connecting to VPN, what is the Local PC IP address?
if the Local LAN and remote LAN have the same IP address?
BB
I am testing with my phone with wifi turned off so just the carrier 5g network.   I connect via the openvpn android client and it gets a IP of 10.1.4.2 the ip address of the vlan on the rv160 is 192.168.1.132.  After I connect I can ping 192.168.1.132 from my phone but I can not access a local webserver on the network with the ip of 192.168.1.164.  I can ping 192.168.1.164 from the rv160 diag interface so I know the router can see that address, but I can not see it through the vpn from my phone.   On my network my primary dhcp server address is 192.168.1.74 so I have dhcp disabled on the vlan1 interface on the rv160.
I have the same issue.
My OpenVPN client gets an IP address from the pool (10.8.1.x).  I can ping to the RV160, but I can not ping devices behind the RV160 router.  All devices on the Vlan have RV160 as default gateway.
Strange...If I add an ACL (any -any) on the RV160 router than I can ping devices on VLAN from my  OpenVpn clients, but from what I have read, you should  not install ACL 's in order to work with OpenVPN clients ??
RV160 Firmware version 1.0.00.17
