PoE on RV016
wjdenihan
I've looked over all the spec sheets and hunted around, can't seem to figure out if the RV016 or RV082 support PoE.  Does anyone know for sure one way or the other?  Assuming it doesn't, what Cisco product would be best to inject PoE on a small business network.  I have 1 RV016, and I'm looking to deploy a RV082 and WAP4410N, with the 4410 being the only device on my network that would need PoE, I'd rather not have to buy a dedicated PoE Switch or Hub just for that one device.  Thanks in advance.
2 Accepted Solutions
edpaz
wjdenihan,
Unfortunately, none of our Cisco Small Business Routers supply PoE, nor can be powered up using PoE. If you are looking to connect a PoE device to one of our routers, Yes you can use a Power injector to do so, going out bound to the device. e.g. WAP4410n you can use the WAPPOE12. You can find this informaton on the WAP4410n Access Point User Guide
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdfhttp://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdfhttp://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdf
I hope this will help.
wjdenihan,
I just talked to one of my fellow engineer, and he has told me that he had a similar issue as yours. Further more, the WAP4410n does say that you can use the WAPPOE12 but the device that supports for internet connection e.g. router, switches will not work. the WAPPOE12 does support IEEE 802.3af. I looked at the users guide for the WAPPOE12(link below) the WAP4410n needs 802.3af for PoE.
So you will need a PoE switch as in a Unmanaged Switch SD2008P would be suffice.
http://downloads.linksysbycisco.com/downloads/WAPPOE12_V10_DS_B.pdf
the WAPPOE12 supports only 802.3, 802.3u.
Sorry for the confusion,
5 Replies 5
edpaz
wjdenihan,
Edgar, Thanks for your prompt and informative response!  Answered all my questions. :-)  I will purchase a WAPPOE12.
wjdenihan,
Ah I see. Thank you for the clarification.  Looks like I will be purchasing a Switch.
Message was edited by: wjdenihan  Just read a review here: http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16833124185   And it appears that at least one person has had luck with a WAPPOE12 working to provide power to a WAP4400N, so I may experiment and see if it will work with the 4410 as well.
So am I to understand that the RV016 is incompatible with any AP that uses a POE injector (NOT a splitter... supplying power from a POE switch, but an injector with an external power supply)? I understand that the RV016 isn't a POE device itself, but usually you could use a POE injector with a POE access point and a non-POE switch. Is that not the case here? Shouldn't I just be able to get a POE injector (with its own power supply), and connect a POE AP to the RV016?
