Port forwarding on Cisco 2811 Router
James Leo
Hi, I am not sure if I am posting in the right section but I have a little problem with NAT I believe.
Basically the problem that I have is that I have a new Exchange server sitting on 192.168.12.2 IP address and on the router I have this NAT enabled
ip nat inside source static tcp 192.168.12.2 110 212.115.5.5 110 extendable
ip nat inside source static tcp 192.168.12.2 25 212.115.5.5 25 extendable
The Exchange can receieve emails but it will not send them. It cannot make connection to any of the smart hosts on port 25 or can't even send mail using DNS. When I run telnet my.smarthost.com 25 it will not connect but if I run that from the router then it connects fine.
Any ideas what I should do or what it could be?
Many thanks
stephen.stack
Level 4
Level 4
Try this
Ip nat inside source static 192.168.12.2 212.115.5.5 25 extendable
Ie remove the 25 after the 12.2 ip address in the nat statement. I think this will only nat outbound connections if sourced on port 25.
Else try a debug ip nat on the router and telnet to your smart host from the exch server to see what's going on. Don't forget to turn off the debug with an undebug all.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
