Hi Guys,
Hope you can assist here. I have port forward my srp527w to have access to my Network Video Recorders over the internet.
My isp issued me a static IP address 110.xxx.xxx.xxx so I assigned static IP addresses on my NVR s and set their Gateway the same as the router's gateway. The IP address I chose were 192.168.15.103 which is out of the range of the DHCP (allocated 100).
I have open ports 2804 and 2805 (as per the vendors specs) and they use tcp .
My problem is I can connect to the NVRs using the vendor software only via tethering on 3G but when I try doing it through wireless it is not letting me connect.
I don't think is the firewall because I have access to other site.
Is there something I am missing out?
Cheers for your help.
