Press RETURN to get started!
ouambo5r1
Please I need help my router 1941 boot and stuck on this message
igitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x410638c
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################# [OK]
Smart Init is enabled
smart init is sizing iomem
                 TYPE      MEMORY_REQ
    Onboard devices &
         buffer pools      0x01E8F000
               TOTAL:      0x01E8F000
Rounded IOMEM up to: 32Mb.
Using 6 percent iomem. [32Mb/512Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 07-Nov-12 12:45 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FTX183684QC
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
245744K bytes of USB Flash usbflash0 (Read/Write)
Uncompressed configuration from 6658 bytes to 12619 bytes%No specific protocol or access-group configured in class Self_to_Public_Inspect_Class for inspection. All packets will be dropped
Leo Laohoo
The settings for the serial port is incorrect.  Maybe Flow Control is enabled?
Thx Leo, I change the serial and it is working now
