Problem using CCA 3.0 to configure sr520w
briansmith99
Just got a new sr520w and tried to configure it using CCA 3.0. I tried using the setup wizard and can connect to it but when I get to the step to modify the WAN (FE4) interface the wizard stops responding - the cursor just spins like it's going to do something but does not bring up the interface properties. I also tried setting it up manually using the CCA but cannot turn off dhcp on the inside interfaces. I am using Windows 7 pro with UAC turned off and no firewall. Any thoughts?
ajstadlin
I am experiencing the same problem with CCA 3.0.1 (EN) and a new SR520W (Fast Ethernet) router.
Attached is a screen shot of the point of failure in the CCA Device Configuration Wizard.
In the Wizard, clicking the Modify button in the WAN configuration page is a repeatable show stopper.
Please let me know with this bug is fixed.  Until then, I will need to do the Device Configuration using a command line terminal.
Arnold
