TOPOLOGY:
RV082 --> (VPN tunnel) --> ASA (used for my VPNs)
(ASA and RV082 connectivity ok)
I configured on Cisco RV082 VPN Client, Gateway To gateway VPN, whith the parameters below:
Tunnel Name : (name of vpn - the same name created in the ASA)
Interface : WAN1
Enable : (checked)
Local Group Setup
Local Security Gateway Type : IP Only
IP Address : 192.168.45.127 (correct IP that use the Cisco VPN RV082)
Local Security Group Type : Subnet
IP Address : 192.168.1.0
Subnet Mask : 255.255.255.0
Remote Group Setup
Remote Security Gateway Type : IP Only
IP Address: (ASA IP Global)
Remote Security Group Type : Subnet
IP Address : 10.100.7.192 (subnet created for the vpn in the ASA)
Subnet Mask : 255.255.255.192
IPSec Setup
Keying Mode : IKE with Preshared key (the same created for vpn in the ASA)
Phase 1 DH Group : Group 2 - 1024 bit
Phase 1 Encryption : 3DES
Phase 1 Authentication : MD5
Phase 1 SA Life Time : 28800 seconds
Perfect Forward Secrecy : (checked)
Phase 2 DH Group : Group 1 - 768 bit
Phase 2 Encryption : 3DES
Phase 2 Authentication : MD5
Phase 2 SA Life Time : 3600 seconds
Preshared Key : (the same for the vpn in the ASA)
Minimum Preshared Key Complexity : (not checked)
No Advanced features configured.
The status of tunnel connections is "waiting for connections".
I don't know why the RV082 can't establishes VPN tunnel with ASA.
There is someone that can help me with this issue?
