problem with WSRV4400N and L2TP
hanan.kenan
I have just bought this router and i am trying to replace a good working router but with no VPN support.
I upgraded this router to Firmware Version:  V2.0.2.1-ETSI and problem still continue
I only set the L2TP Server , user and password.
I also tried to assign an IP, GW and mask after my old , active Router got them and this is still not working ..
this is my error log:
Jan  1 00:00:07  - bind 0.0.0.0 - Address already in use
Jan  1 00:00:07  - started as root without requesting chroot(), warning only
Jan  1 00:00:07  -  starting on , port 80
Jan  1 00:00:15  - eth2: no IPv6 routers present
Jan  1 00:00:16  - eth0: no IPv6 routers present
Jan  1 00:00:16  - eth1: no IPv6 routers present
Jan  1 00:00:17  - br0: no IPv6 routers present
Jan  1 00:00:21  - br0: port 2(eth2) entering forwarding state
Jan  1 00:00:21  - br0: topology change detected, propagating
Jan  1 00:00:21  - br0: port 1(eth0) entering forwarding state
Jan  1 00:00:22  - This binary does not support kernel L2TP.
Jan  1 00:00:22  - l2tpd version 0.69 started on  PID:185
Jan  1 00:00:22  - Written by Mark Spencer, Copyright (C) 1998, Adtran, Inc.
Jan  1 00:00:22  - Forked by Scott Balmos and David Stipp, (C) 2001
Jan  1 00:00:22  - Inhereted by Jeff McAdams, (C) 2002
Jan  1 00:00:22  - Linux version 2.4.27-star on a armv4l, port 1701
Jan  1 00:00:22  - l2tp_call:Connecting to host 212.25.127.19, port 1701
Jan  1 00:00:22  - handle_avps: handling avp's for tunnel 4748, call 0
Jan  1 00:00:22  - message_type_avp: message type 2 (Start-Control-Connection-Reply)
Jan  1 00:00:22  - protocol_version_avp: peer is using version 1, revision 0.
Jan  1 00:00:22  - framing_caps_avp: supported peer frames:
Jan  1 00:00:22  - firmware_rev_avp: peer reports firmware version 4400 (0x1130)
Jan  1 00:00:22  - hostname_avp: peer reports hostname 'L2TP-ASR-1-PTK'
Jan  1 00:00:22  - vendor_avp: peer reports vendor 'Cisco Systems, Inc.€^H'
Jan  1 00:00:22  - assigned_tunnel_avp: using peer's tunnel 9361
Jan  1 00:00:22  - receive_window_size_avp: peer wants RWS of 16.  Will use flow control.
Jan  1 00:00:22  - control_finish: Connection established to 212.25.127.19, 1701.  Local: 4748, Remote: 9361.
Jan  1 00:00:22  - lac_call: Calling on tunnel 4748
Jan  1 00:00:22  - handle_avps: handling avp's for tunnel 4748, call 2732
Jan  1 00:00:22  - message_type_avp: message type 11 (Incoming-Call-Reply)
Jan  1 00:00:22  - assigned_call_avp: using peer's call 4591
Jan  1 00:00:22  - control_finish: Call established with 212.25.127.19, Local: 2732, Remote: 4591, Serial: 1
Jan  1 00:00:22  - pppd 2.4.1 started by root, uid 0
Jan  1 00:00:22  - using channel 1
Jan  1 00:00:22  - ppp0 Using interface ppp0
Jan  1 00:00:22  - ppp0 Connect: ppp0 <--> /dev/ttyp0
Jan  1 00:00:22  - Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan  1 00:00:24  - download uses obsolete (PF_INET,SOCK_PACKET)
Jan  1 00:00:25  - Kris Linux Driver:Version=v2.00 for CISCO's RVSR000,WRVS4400N & WRVS4400Nv2(Feb 18 2009:18:16:43)
Jan  1 00:00:25  - Enable Tcp Connection Tracking
Jan  1 00:00:25  - The Total Used Table Memory Size = 0xFB4878 = 16082K
Jan  1 00:00:25  - Trying to free free IRQ16
Jan  1 00:00:25  - Trying to free free IRQ17
Jan  1 00:00:30  - Kris is unlocked
Jan  1 00:00:30  - Reset IDP Engine!!!
Jan  1 00:00:30  - The Total Used Table Memory Size = 0xFB4878 = 16082K
Jan  1 00:00:30  - Enable DDOS Detection!!
Jan  1 00:00:30  - Enable PortScan Detection!!
Jan  1 00:00:30  - Enable IP Sweep Detection!!
Jan  1 00:00:50  - init_network: Unable to bind socket. Terminating.
Jan  1 00:00:54  - No response to PAP authenticate-requests
Jan  1 00:00:54  - Connection terminated.
Jan  1 00:00:54  - death_handler: Fatal signal 15 received
Jan  1 00:00:54  - destroy_call: We will kill pppd!
Jan  1 00:00:54  - ppp0 Terminating on signal 15.
Jan  1 00:00:54  - PPPIOCDETACH file->f_count=4
Jan  1 00:00:54  - Couldn't release PPP unit: Invalid argument
Jan  1 00:00:54  - tcflush failed: Input/output error
Jan  1 00:00:54  - Exit.
Please Advise .
thanks
mpyhala
Level 7
Level 7
Hello Hanan,
Thank you for posting. I am a little unclear about what you are attempting to do. The WRVS4400N has L2TP passthrough but no L2TP server. Are you having trouble with L2TP passthrough to another server?
I am trying to connect to my cables L2TP server.
I am having IP from the cable modem if i chose dynamic IP option just to verify from all is good from cable mode to ISP.
I also try connect with the same l2tp , user , password from a DLINK DIR-655 and all works fine.
When i take the DIR0655 out and put this one i get the errors above.
So i guess i have  trouble with L2TP passthrough to another server although this error "Jan  1 00:00:54  - No response to PAP authenticate-requests" is very strange ...
hanan
