Showing results forĀ
Search instead forĀ
Did you mean:Ā
QoS binding limited to IP address range and SSID on WLAN
Joergen Thomsen
Our VLAN id 2 is used only by a WLAN SSID
Defining a QoS profile as using VLAN id 2 did not work. No upper rate limitation worked
Only using the IP address range of the VLAN or the SSID appeared to work.
It does not appear consistent, when a VLAN id can be specified on a WLAN in the  Wireless Basic Setting Table
It is also inconsistent, that the proper SSIDs are not listed in the drop down box on the
Add / Edit Profile Binding Configuration page. They only appear as AP-1, AP-2 etc.
Joergen Thomsen
This is on the RV220W using firmware 1.0.3.5
Has this been fixed under firmware 1.0.4.17? I cannot get this work with any type of Traffic Selector (IP/MAC/VLAN/DSCP/SSID).
Any suggestions are greatly appreciated. Thanks!
