QuickVPN doesn't connect to RVS4000
AleckNesterov
I've installed QuickVPN on Windows XP, configured an account on the router.
But when I'm trying to connect to the router I get the following:
MS NT5 ISAKMPOAKLEY 00000004]
Oct 2 06:25:33 - [VPN Log]: packet from 1.1.1.1:500: ignoring Vendor ID payload [FRAGMENTATION]
Oct 2 06:25:33 - [VPN Log]: packet from 1.1.1.1:500: received Vendor ID payload [draft-ietf-ipsec-nat-t-ike-02_n] method set to=106
Oct 2 06:25:33 - [VPN Log]: packet from 1.1.1.1:500: ignoring Vendor ID payload [Vid-Initial-Contact]
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: responding to Main Mode from unknown peer 1.1.1.1
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: Oakley Transform [OAKLEY_3DES_CBC (192), OAKLEY_SHA1, OAKLEY_GROUP_MODP1024] refused due to strict flag
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: transition from state STATE_MAIN_R0 to state STATE_MAIN_R1
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: STATE_MAIN_R1: sent MR1, expecting MI2
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: NAT-Traversal: Result using draft-ietf-ipsec-nat-t-ike-02/03: no NAT detected
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: transition from state STATE_MAIN_R1 to state STATE_MAIN_R2
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: STATE_MAIN_R2: sent MR2, expecting MI3
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: Main mode peer ID is ID_IPV4_ADDR: '1.1.1.1'
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: I did not send a certificate because I do not have one.
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: transition from state STATE_MAIN_R2 to state STATE_MAIN_R3
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: STATE_MAIN_R3: sent MR3, ISAKMP SA established {auth=OAKLEY_PRESHARED_KEY cipher=oakley_3des_cbc_192 prf=oakley_md5 group=modp1024}
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: cannot respond to IPsec SA request because no connection is known for 192.168.160.0/24===2.2.2.2[S?C]...1.1.1.1[S?C]
Oct 2 06:25:33 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: sending encrypted notification INVALID_ID_INFORMATION to 1.1.1.1:500
Oct 2 06:25:34 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x9995a83b (perhaps this is a duplicated packet)
Oct 2 06:25:34 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: sending encrypted notification INVALID_MESSAGE_ID to 1.1.1.1:500
Oct 2 06:25:36 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x9995a83b (perhaps this is a duplicated packet)
Oct 2 06:25:36 - [VPN Log]: "user1_rw_rw"[1] 1.1.1.1 #2: sending encrypted notification INVALID_MESSAGE_ID to 1.1.1.1:500
Can anybody help with this?
Thanks in advance.
davbarre
Hi Aleck,
Can you please post your Quick VPN log as well?  It's default location is C:\Program Files\Cisco Small Business\Quick VPN Client
Located in this directory is a log.txt file.
Thanks!
Dave
David L. Barrett, Jr.
Unfortunatelly OpenVPN doesn't save logs
Here is a list of files:
23.10.2010  15:50
23.10.2010  15:50              ..
16.11.2009  13:31           155 705 CFP.exe
16.11.2009  13:31             2 958 Cisco.ICO
09.12.2009  13:26            14 848 DetectEnvStatus.exe
02.10.2010  11:46              Image
02.10.2010  17:38               132 ipsec.conf
12.04.2010  14:11            61 440 IPSEC.exe
16.11.2009  13:31           154 112 IPSec.msc
16.11.2009  13:31            71 680 ipseccmd.exe
16.11.2009  13:31            19 968 IPSECUTIL.DLL
02.10.2010  17:38                 0 isakmp_status.conf
16.11.2009  13:31         1 097 728 libeay32.dll
23.10.2010  15:50                 0 list.txt
16.11.2009  13:31            16 121 News
02.10.2010  23:59                 1 Op.txt
16.11.2009  13:31           315 392 openssl.exe
16.11.2009  13:31           106 496 PingDLL.dll
16.11.2009  13:31            49 210 ProcNICs.dll
02.10.2010  11:48              profiles
16.11.2009  13:31               246 Readme.txt
02.10.2010  17:08               798 RVS4000_Client.pem
02.10.2010  11:47               105 rw.INI
12.01.2010  15:46           217 088 rw_client.dll
16.11.2009  13:31           118 784 rw_regedit.exe
16.11.2009  13:31             4 022 sample.wgetrc
16.11.2009  13:31           200 704 ssleay32.dll
03.10.2010  00:00                79 status.conf
02.10.2010  17:39                56 stopconn.conf
16.11.2009  13:31            22 191 strings.txt
16.11.2009  13:31            20 480 TEXT2POL.DLL
16.11.2009  13:31             1 078 uninstall.ico
13.05.2010  11:04           581 632 VPNClient.exe
16.11.2009  13:31               673 VPNClient.exe.manifest
16.11.2009  13:31            71 146 VPNClientHlp.chm
03.10.2010  00:00                 0 vpnserver.conf
16.11.2009  13:31           221 184 wget.exe
16.11.2009  13:31           148 259 wget.hlp
16.11.2009  13:31           186 238 wget.html
03.10.2010  00:00               299 wget_error.txt
02.10.2010  17:38               365 wget_request_error.txt
02.10.2010  17:39               547 wget_stop_error.txt
imantspetrovs
deleted
