QuickVPN SSL connection issue to RV042 only through specific ISP
ggprod1976
I've noticed a frequent problem using QuickVPN to connect through a RV042.  With a specific ISP (Rogers cable internet in Canada) occasionally from a particular location QuickVPN will stop being able to connect into my work VPN (though a RV042), although it had been connecting fine before (and can often connect through the same ISP at a different location).  Although the RV042 is contactable and a TCP connection is formed, the SSL connection fails and the problem persists indefinitely.  If I connect the same computer (a Windows Vista laptop) to a different ISP I am able to connect fine.  Rebooting the cable modem/router do not solve the problem.  I once saw a similar problem occuring with a different ISP (Bell DSP internet in Canada), but in that case rebooting the DSL modem/router solved the problem.
I suspect the edge-router in the ISP encounters some problem pertaining to SSL connection routing.
Has anyone experienced this issue or knows a resolution?
thanks,
Mark
The only configuration for PPTP is to enable the feature, specify the subnet the router assigns to the connecting user then make a PPTP user. It's about as fast as QVPN and uses the built-in MS client.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
7 Replies 7
Tom Watts
Hi Mark, it may be possible, that specific ISP modem/router box has the same IP subnet on the LAN as the RV042 you're trying to connect to.
Does the QVPN log reveal any details?
-Tom
Hi Tom,
Thanks for the response.  The subnets involved (the local LAN subnet and the subnet of the RV042) are different.  The QuickVPN log says SSL connection failure.  When I do a network capture of the failed quickvpn connection I see that a TCP connection is opened between my laptop and the RV042 and the QuickVPN application sends SSL client hello packets to the RV042 but do not receive the necessary SSL ack-response packets in return (the client hello is repeated a few times without response and then the connection is reported as failed)
Mark
It is possible the return packets are not making it back to your computer. I have seen in some isolated instances where there is not enough bandwidth (upload) for the connection to the point it times out. I have also seen in some very rare occasions the outbound router drops/blocks the ESP packets coming back.
The interesting note is, if you use PPTP there is likely no problems as it is a lighter tunnel with less requirements.
-Tom
hi Tom, is there a way to use PPTP with the RV042?  Would that require re-configuring the RV042 in a way such that all users had to start using PPTP?  Are there any other configuration changes or other clients that I could try to solve the problem (when trying to connect through the ISP that gives problems) that wouldn't require re-configuring the RV042 in way such that all other users had to change their access method?
thanks,
Mark
-Tom
Thanks Tom, I'll give that a try and see if it solves my issue with connection through the problem ISP
Switching to using PPTP solved my problem.  Thanks Tom!
