Replacing Three Branches C891F Routers
Hitchens
I'm looking for suggestions to replace three branches C891F routers.
The corporate office uses DMVPN Hub, SSLVPN and NAT.
The two branch offices are configured with DMVPN spoke with NAT.
What would be a comparable Cisco router replacement for these three routers?
Hitchens.
Francesco Molino
I would go with ISR 111X series.
Here the datasheet link: https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
You won't have the ssl vpn feature. You can still use anyconnect but for IPsec (flexvpn).
On IOS-XE you want have this choice except the virtual router csr1000v.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
balaji.bandi
