router cisco ISR 4351 not connect to internet
josecervini
I have been trying to configure my router for several days but I have not been able to get it to log in or out of the internet. I would be very grateful if you could help me since my business depends on this router, this is my running-config:
Building configuration...
Current configuration : 2872 bytes
! Last configuration change at 10:15:52 UTC Tue Jun 25 2024
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform hardware throughput level 400000
hostname R1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 xxxxxxxxxxxxx
enable password xxxxxxxx
no aaa new-model
subscriber templating
passthru-domain-list jose
match lolyschicken.com
match 192.168.1.1
match cisco.com
match www.goolge.com
license udi pid ISR4351/K9 sn xxxxxxxxx
license accept end user agreement
license boot level appxk9
diagnostic bootup level minimal
service-template webauth-global-inactive
inactivity-timer 3600
service-template DEFAULT_LINKSEC_POLICY_MUST_SECURE
linksec policy must-secure
service-template DEFAULT_LINKSEC_POLICY_SHOULD_SECURE
linksec policy should-secure
service-template DEFAULT_CRITICAL_VOICE_TEMPLATE
voice vlan
username xxxxx privilege 15 secret 9 xxxxxxxx
redundancy
mode none
parameter-map type webauth global
login-auth-bypass ip-access-list 100 domain-name-list jose
interface GigabitEthernet0/0/0 (wan dhcp)
ip address dhcp hostname R1
ip nat outside
ip access-group 100 out
negotiation auto
spanning-tree portfast disable
interface GigabitEthernet0/0/1
ip nat inside
ip access-group 100 in
negotiation auto
no mop enabled
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip nat pool 1 192.168.1.0 192.168.1.254 netmask 255.255.255.0
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip nat outside source list 100 pool 1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http secure-trustpoint CISCO_IDEVID_SUDI
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
access-list 100 permit tcp any any eq www
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/0
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password xxxxxxxxx
login
length 0
end
35 Replies 35
add
ip routing
and check again ping
MHM
I add but ping still missing, SUCCESS RATE IS 0 PERCENT (0/5)
in router do traceroute 8.8.4.4
share result here
MHM
1 *  * *
2 * * *
3 * * *
And still to 20 (I stop it)
the ISP is not respond to ICMP
let do other check
add to router
ip domain-lookup
ip name-server 8.8.8.8
then do
Router#debug ip domain detail
Router#google.com
the debug must show the google name resolve to IP
MHM
sorry there is issue with your ISP it not router or config
the  ISP is deny any traffic no ping no traceroute no even DNS UDP53
contact ISP and explain the issue.
thanks a lot
MHM
Thank you for your time, the only thing that seems strange to me is that the Cisco 2921 router works fine, with the same ISP, same modem, at this point I disconnected the 4351 router from the modem and connected the 2921 and it worked normally.
wait a min
can you share last config you use ?
MHM
this last, right now download it
Current configuration : 2084 bytes
! Last configuration change at 18:59:19 UTC Thu Jun 27 2024
version 16.6
hostname R1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 xxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxxxxxxxxxxxx
no aaa new-model
license udi pid ISR4351/K9 sn xxxxxxxxxxxxxxxxx
username xxxxxxxxxxxxxx privilege 15 secret 9 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
redundancy
mode none
ip nat outside
negotiation auto
ip virtual-reassembly
ip nat inside
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
ip nat inside source list 20 interface GigabitEthernet0/0/0 overload
ip http server
ip tftp source-interface GigabitEthernet0
access-list 20 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password xxxxxxxxx
login
end
I was suspect about you add ACL under interface, there is no such this ACL anymore
so we return there is nothing in your config, contact ISP it can have ACL for Mac address and accept only the old router when you connect new one the ACL deny any traffic.
Goodluck
MHM
Definitely tomorrow I will call and ask for flush dns and refresh the modem
Thanks for your help, I already managed to ping from my WAN interface but now I have no ping or connection from my lan gig0/0/1, what command am I missing?
Current configuration : 2558 bytes
! Last configuration change at 05:13:27 EST Fri Jul 5 2024
! NVRAM config last updated at 05:00:47 EST Fri Jul 5 2024
version 16.6
hostname R1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone EST -23 0
ip name-server 192.168.1.1
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp pool pool1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
match www.cisco.com
match www.google.com
match 8.8.8.8
match 192.1681.1
username xxxxxxxxxxxxxxxxxx privilege 15 secret 9 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
redundancy
mode none
ip nat outside
negotiation auto
ip nat inside
ip access-group 20 out
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
I remove the old line and add suggestion line but still same, not ping outside
As per the config i don't see below line - it was there in the original configuration
as i mentioned in the old post you need to start basic configuraiton and gradually improve the config based on the requirement. if the basic not working adding advanced config not going to help you and if you do not understand what that command does.
Lets start again :
From router you able to ping 8.8.8.8 ?
#ping 8.8.8.8 - is this works ?
#ping x.x.x.x (ISP gateway IP ?)
if that works then move to next level of my above command NAT.
If router not ping ISP or 8.8.8.8
check below commands :
#show ip interface brief (this give you if the ISP gave IP and Interface up)
#show ip route - this give you ISP route
Clear and simple config as below :
https://www.balajibandi.com/?p=1796
BB
