Router RV340 connecting to AVM Fritz 7490
MaxlGraf01
Hi all!
I've got trouble using VPN connections with the RV340 small business router.
When trying to connect to the router with Anyconnect under Windows client (i.e. on Windows 10) from outside I can´t get any connections.
Here is some information on my setup:
  • RV340192 with firmware 1.0.3.15
  • It connects to the Internet using PPPoE dialin
  • dyndns account configured and working
  • Another router working in "Act as a DSL modem" mode is used as a modem (AVM FRITZ!Box 7490)
  • The RV340 should maintain a IPSec tunnel to clients from outside to office
Which ports must be opened at the first router AVM Fritz!Box to reach the RV340?
The RV340 is connected to a internal WIN2019 server, from here access to the internet is working.
Where can I register for the two free ANYCONNECT liceses, cause if I try to open the web site I always get
the hint "This is taking more time than expected. Please try to login again after 15 minutes." again and again.
Any help would be very much appreciated.
Maxl
nagrajk1969
1. At the outset, and maybe you may have already configured it,
a) create a user-group (with local-user-accounts) and in the properties of this user-group, select the SSLVPNDefault profile...
b) and then do a apply and a permanent save too
2. Next follow the instructions in the below link for configuring anyconnect vpn on RV34X (for some reason it does not mention anything about point-1 requirement above...so create and assing the user-group to the sslvpn service/profile before hand)
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5553-configure-anyconnect-virtual-private-network-vpn-connectivit.html
3. For any future and further requirements of info on howtos/etc for RV34X routers, refer to below site
https://www.cisco.com/c/en/us/support/smb/product-support/small-business/routers-340-family.html
4. And refer to below for much more info on the small-business routers etc
https://community.cisco.com/t5/small-business-routers/helpful-support-links-emulator-video-tutorials-support-pages/m-p/4447380#M41732
