12-22-2011 01:11 PM
I just installed a new RV 120W to replace my dlink router.
The problem is i cant display the configuration site (192.168.1.1)
My internet is working fine and when i go to 192.168.1.1 i can logon (with the password i set using the installation disk) but then i see the top of the config site (blue) but where the config panel should be i see `site cannot be displayed`.
I tried using my laptop and pc on diffirent ports.
I´ve tried using IE9 and Chrome version 16,0,912,63
I´ve also tried to reset the router but this all has no effect.
Can you please advise? Thanks a lot!
Kind regards,
Jesse
Solved! Go to Solution.
01-02-2012 07:48 PM
01-02-2012 07:48 PM
01-03-2012 04:52 AM
Hi guys,
sorry for spam, but I don´t know how to start new topic for Cisco RV 120w.
I have problem with "autostart" of VPNs after reboot (auto reconnect). When I manually press on Connect in IPsec Connection Status, VPNs will be connected, but I want to do this automatically after reboot.
Can anyone please let me know where to set it?
Thanks a lot,
Petr
01-03-2012 01:42 PM
Thanks a lot! This is the solution.
Kind regards,
Jesse Schmidt
01-09-2012 07:20 AM
Jesse,
I fought that issue when I set up the router some time ago. I had posted a "heartfelt" plea to Cisco to address issues like this. But I just deleted it because, quite by accident, I found that I no longer have this problem. That is, I can access the administration page over HTTP and HTTPS just fine. I don't know when this change occured because I had assumed that HTTPS was not to be used for security of the password used to log on, so I never tried HTTP again, until by accident since I saw your post.
So now I don't know if this changed in version 1.0.2.6, or is a browser compatibility issue, or what (it is not mentioned in the release notes.) My current configuration is firmware 1.0.2.6 and IE 9, and that works for both HTTP and HTTPS.
I now have another issue, and that is I can't find that the option "HTTPS Web Access on LAN Interface" on the Web Access page does anything at all, but that is a separate topic.
Brandt Braunschweig
