RV 180w with VLAN / NAT / VPN and VOIP
cluck_hurst76
Good day,
I've looked over the internet with various searches and haven't had luck nailing down a solution to this problem. I have a Site-to-Site IPSEC VPN between a remote location and the office.  The remote location has a Cisco RV180w with the latest firmware. The office, using a TP-LINK TL-ER604W router.
The VPN is linked and I can access file shares, remote desktop without a challenge. The problem seems to be with Audio using an IP phone.
* Office to Remote calling works, we can hear each other.
* Remote to Office calling, they can hear me but I cannot hear them.
* Remote Calling to any number works, same issues: I can hear them, they cannot hear me.
* Access to Voice Mail using Softkeys - connects, I can hear the prompts - but key tones (DTMF) are not functioning to go through Voicemail
Remote Location Setup
RV180w
Firmware:1.0.5.4
VLAN 1: 10.50.0.0/24
VLAN 2: 192.168.55.0/ /24
VLAN 3:  10.80.80.0 /24   (used to connect to VPN)
Routing Mode : Gateway (NAT)
Routing Table: see attached file
Firewall Access Rules:  Allow all, Block specified (nothing set)
Port Forwarding: None
DMZ: None
SIP ALG: Enabled
QoS: None
UPnP: Disabled
This router is behind an ISP router, used for IPTV and Internet.  The DMZ is enabled and set to the static IP on the WAN side of 192.168.2.253.
Office Setup
TL-ER604W
Firmware: 1.1.0 Build 20141031
LAN; 10.30.30.254
NAT Enabled
NAT-DMZ: Disabled
Multi-Nets Nat: Not Configured
ALG:   FTP ALG, h.323 ALG, SIP ALG, IPsec ALG, PPTP ALG - all Enabled
Access Control Rules: None
UNPnP; Disabled
Any suggestions would be welcome.
cva32j
I have your same problem. Have you resolved the problem? How did you do it?
Regards.
